Hey guys. I'm a it guy at my local church. The pastor that owns the house next to it wants to use his Internet at the church so they don't have to get Internet for the church because of how much it would cost because it would technically would be a commercial building. Anyways the way we're doing it now is he has a Asus a66r router. I have a netgear extender at the church taking the wifi signal and extending it for the computers and devices in the church but it doesn't get a great signal because of the distance between the router and the extender and causes slow speeds. I'm wondering if there is a better way of getting Internet to the church than wifi? Thanks
Specs: CPU: Intel I7 4790k @ 4.7ghz  GPU: GTX 1660 TI
https://linustechtips.com/topic/332884-same-internet-across-2-buildings-help/
CPU - Intel Core i7 4770K @ 4.80GHz / GPU - MSI GTX 980 4GB Gaming / RAM - 16 GB G.Skill TridentX 2400 MHz / Motherboard - Maximus VI Formula / CPU Cooler - Kraken x60 / Power Supply - Rosewill Lightning 1300w / Case - Enthoo Luxe Monitor - Asus ROG Swift PG278Q / Sound - Razer Kraken 7.1 / Keyboard - Razer Blackwidow Chroma / Mouse - Razer Naga Hex + Razer Deathadder Chroma | Picture - [http://i.imgur.com/SSKZKWu.jpg]
Since when does jesus need internet.
jesus that need to put pictures on facebook of his visit to bethlehem
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
theres no way cat 5e can get 1000 ft.
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
Then go with 6...  probably doesnt even need to be 1000ft xD
I'm pretty sure cat 6 is still limited to 100m, but that isn't small by any means and should get the job done in most cases, if it suppresses that, or about equals it I wouldn't bother with it (unless you want to get slightly longer cables and deal with slightly worse internet, but that is better than nothing.
Jesus-Facebook-Page.png this is so bad
Are you sure this is legal in your area?
I honestly don't see how this could be illegal anywhere in the United States, there is no law that say's you can share your Internet.
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
Or you could just buy a high gain antenna, add a password on the signal and just share it with your congregation.
You will want some Cat 6 (thicker gauge, last longer, can also go just a bit further), a repeater, and a wireless AP. Run the cat6 from the house to the church, depending on the distance, you can get away with running Cat6 600 feet but rule of thumb is each run from the router should be no more than 100meters. If the distance is further than this you will need a repeater somewhere in the middle. in the church set up a wifi router as an Access point so it only provides wifi and uses the internet coming from the house over the cat 6.
You can get some Ubuiquit airMax point to point solutions for pretty cheap, that would be my solution.
https://www.ubnt.com/products/
Running a cable would be okay, but for the amount of time you will spend digging a trench etc it doesn't seem worth it
You can use Ubuiquit nano bridge equipment:
http://www.newegg.com/Product/Product.aspx?Item=0ED-0005-000H4&cm_re=nano_bridge-_-0ED-0005-000H4-_-Product
Or if the distance is less than 100m end-to-end use outdoor rated ethernet cable.
CPU: i7 3770k @ 4.8Ghz Motherboard: Sabertooth Z77 RAM: 16GB Corsair Vengeance GPU: GTX 780 Case: Corsair 540 Air Storage: 2x Intel 520 SSD Raid 0 PSU: Corsair AX850 Display(s): 1x 27" Samsung Monitor 3x 24" Asus Monitors Cooling: Swifttech H220 Keyboard: Logitech 710+ Mouse: Logitech G500 Headphones: Sennheiser HD 558 --- Internet: http://linustechtips.com/main/uploads/gallery/album_1107/gallery_12431_1107_23677.png My Setup:  http://linustechtips.com/main/gallery/image/7922-1-rkcf7io/ -- NAS: 3x WD Red 3TB Drives (RAIDZ-1), 5x 750gb Seagate ES HDD(RAIDZ-1), 120gb SSD for caching, OS: FreeNAS --  Server 1: Xeon E3 1275v2, 32GB of RAM, OS: ESXi 5.5 -- Server 2: Xeon E3 1220v2, 32GB of RAM, OS: ESXi 5.5
@Critizin indeed, Cat 5, 5e, 6, 6a, and even 7, all have 100m (~330 feet) maximum cable runs for a segment. To extend it beyond this length, you'd need to use a switch, router, or repeater between cable lengths.
@orbofshingeki how far away are the two buildings? I'm guessing that you'll need to run more than 330 feet of cable. If so, your best bet would be getting a pair of Gigabit Fibre media converters - Something like this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16833114104&cm_re=gigabit_fiber_converter-_-33-114-104-_-Product
or this:
http://www.newegg.com/Product/Product.aspx?Item=9SIA4SM26G7620&cm_re=gigabit_fiber_converter-_-9SIA4SM26G7620-_-Product
And then getting the necessary compatible Fibre cable (making sure to get the right connector and media type as specified by the media converter you end up buying). Gigabit Fibre can be run over 1km with the right type of cable and protocol used.
The tricky bit is finding the right type of cable that can be run long enough, plus finding a media converter that will support that cable.
In any case, whether the distance is short enough to run via Ethernet, or whether you need to go with Fibre, I'd suggest buying some PVC or Copper pipe, and running the cable inside the pipe. Ideally, you'd bury the pipe as well for additional protection and to keep it out of sight.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
or this:
For those prices you can just get 2 x used 24 port switches with fiber. and cut out the converters and you have switches on both ends also. Fiber seems very expensive just to get a very low demand connection on the other end
Indeed, getting a switch with a built-in Fibre converter may very well be the cheapest option. Especially if the OP is willing to look at used enterprise grade hardware from the likes of eBay, which can often be had for cheaper then new consumer grade entry level stuff.
Expensive, yes, but he's not happy with the current Wifi range extender option, and Ethernet is potentially not an option due to distance.
A directional Wifi transmitter and receiver may also be an option. @Darren, how is the range on those 5 GHz nanostations? The 5 GHz band has inherently shorter maximum distances compared to traditional 2.4 GHz - but the lack of interference from other wireless signals may make up for that.
directional antenna..I set this up for my uncle on his farm with his neighbours
That's what I was thinking maybe if running Ethernet or Fibre is not feasible for one reason or another.
isn't much cheaper and convenience for long term if you just apply internet connection to the church?
and, idk... I've read somewhere that church is tax free.
all solutions been pointed out
but it will cost a bit, and not to mention regular monitoring
I'd definitely go with either the Ubiquiti airMax nanostations, they're pretty much perfect for this if you've got line of sight between the two points.
CPU: Ryzen 9 5900X @ 4.7GHz | GPU: EVGA RTX 3080 | Motherboard: X570 I AORUS PRO WIFI | RAM: G.SKILL Trident Z RGB 32GB | Case: NCase M1 v6.0 | SSDs: Samsung 970 Evo+ 1TB, 860 Evo 1TB | CPU Cooler: H100i ELITE CAPELLIX | MonitorsLG 27GN950-B 4K 165Hz |
Not Darren, but they do up to 15Km
I got 60Mbps through an 800 metre link. Anything over a couple kilometres I'd go for the Nanobeams.
