Astro A40s, or Audio-Technica ATH-M50's?
Exhilarare
I plan on replacing my Steelseries Siberia V2's, wanted to get one of these.
Astro A40's with Mixamp ($250)
http://goo.gl/iUo8GF
or
Audio Technica ATH-M50 ($130)
http://goo.gl/UxP8o
If I buy the M50's, I will probably get the Audio-Technica AT2020USB ($130) desktop mic with it.
http://goo.gl/DxNOEi
What would be the better buy?
I'll be using this for streaming on Twitch.
EDIT: OR the new HyperX Cloud II's. ($100)
http://www.amazon.com/HyperX-Cloud-Gaming-Headset-Mobile/dp/B00SAYCXWG/ref=sr_1_1?ie=UTF8&qid=1423049512&sr=8-1&keywords=hyperx+cloud
CPU: AMD FX-6350@4.2Ghz GPU: EVGA GTX 970 SC ACX2.0 RAM: 2x4Gb Kingston Fury Black + 2x4Gb Corsair Vengeance HDD: WD Green 1Tb SSD: Kingston SSDNow V300 60Gb CASE: DeepCool Tesseract SW
 http://pcpartpicker.com/p/fJLRWZ
@Exhilarare M50 + AudioTechinia AT2020
Mic is much better and not a huge fan of Astro sound.
You could get a ModMic and then get an even better headphones.
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
Sennheiser HD558 at $90 would probably be the best buy imo. I would definitely go for the 558's over the M50's. Astro's are overpriced. Not sure about Kingston (it has good reviews though).
http://www.amazon.com/Sennheiser-HD-558-Headphones/dp/B004FEEY9A
Rig: i7 2600K @ 4.2GHz, Larkooler Watercooling System, MSI Z68a-gd80-G3, 8GB G.Skill Sniper 1600MHz CL9, Gigabyte GTX 670 Windforce 3x 2GB OC, Samsung 840 250GB, 1TB WD Caviar Blue, Auzentech X-FI Forte 7.1, XFX PRO650W, Silverstone RV02 Monitors: Asus PB278Q, LG W2243S-PF (Gaming / overclocked to 74Hz) Peripherals: Logitech G9x Laser, QPad MK-50, AudioTechnica ATH AD700
How much cash do you want to put into streaming? I would recommend using that $130 budget that you have for the mic and get a Snowball. And if youre serious about streaming, use that money you saved by getting a Snowball and do some acoustic treatment for you room. Or just be happy that you saved money
PC Audio Setup = Beyerdynamic DT 770 pro 80 ohm and Sennheiser pc37x (also for xbox) hooked up to Schiit Fulla 3
Audio Technica ATH-M50 + Modmic (If you dont mind the cable clutter)
Try looking for the M50X as it has a removable cable + better accessories.
If only the M40x didn't sound the same as the M50/M50x. If only it didn't come with the better pads, removable cable, and was cheaper at the same time. Damn this cruel world...
We need to make this into some kind of game.
Don't tempt me tho...
Alright, I've decided im going to get the AT2020 regardless, which of these has the best quality? And I should get the M40x's instead?
It depends what is the price of M40x. If it's <100$ go for M40x. I'm using M50x by myself and they sound great, but I read on reviews that M40x just are fine.
"I am like ninja, but less gay" - Deadpool
Try with ATH-M50's with blue which seems to be good.
Problem being that they are hella overpriced
It's like talking to a wall.
I guess most don't hate money.
Walls dont echo what others say mindlessly.
When you think about it they kind of do, tho.
mike The Mic echo clap
Walls around you only echo your own brilliance. On the internet, random bricks echo other idiots.
Bricks echoing bricks, which explains the brain damage that all these bricks cause.
