Watercooling isn't necessary.
https://linustechtips.com/topic/294315-water-cooling-necessary/#findComment-3996257
no
https://linustechtips.com/topic/294315-water-cooling-necessary/#findComment-3996340
No, watercooling is only used for extreme overclocking
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/294315-water-cooling-necessary/#findComment-3996378
I am only doing it for the looks..
In that case I'd reccomend a dual 480 setup, with LEDs all over the place, and noctua NF-12 industrials.......j/k
Honestly a half decent cpu built within the last few years, shouldn't be loaded up enough gaming at 60 fps, and 1080p. unless you're using a chips onboard graphics. if you are (cringes) you might want in invest in some LN2.....
https://linustechtips.com/topic/294315-water-cooling-necessary/#findComment-3997284
That would not go well with the themed build :)
@syrazpc - for all my rambles about PC's -- My Gallifreyan Build In Progress
https://linustechtips.com/topic/294315-water-cooling-necessary/#findComment-3997464
There are a number of air cooling options that are equal to a number of the lower to common aios out there, and usually cheaper and more efficient to a certain point. After that it gets a bit complicated. Either way, both air and water are viable, but you likely won't need to water cool. Just don't buy very small, and cheap, water coolers for looks, as they are quite inefficient.
Still new, but learning
i7 4790K / GTX 970 G1 Gaming / Maximus VII Hero / Swiftech H240x / Corsair Vengeance Pro 16gb, 1600mhz, cl9 / 850 evo 250GB /
WD Blue 1TB / HX850 / Phanteks Enthoo Pro
https://linustechtips.com/topic/294315-water-cooling-necessary/#findComment-3997817
