what's wrong with mcafee
spwath
Well? I'll have to use it for 10 months, what's wrong with it?
Bad on system resources, anti virus doesn't do jack to protect a system, it's sluggish, low on how much it protects... Just junk.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
2 words. CRAP. WARE.
But it doesnt do anything bad?
Everything.
Get rid of it and get avast.
It not protecting you very well could be considered a bad thing.
Almost as bad as norton. Doesn't hlep much, false alerts, uses up system resources.
If you turn scheduled scans off it shouldn't hurt your performance much, but malwarebytes is far better.
Even Avast detects it as crapware
why? That is should be in the bill of right, you a free to use any anti virus you want.
LOL, made my day :D
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
LOL, made my day :D$60 Mail-in-Rebate with the purchase of McAfee Multi Access from
TigerDirect & Ebay (BUNDLEOFFER).
1. Purchase a qualified product listed on this form between 8/14/2014 and 12/31/2014.
2. Go to http://mcafee.4myrebate.com/?oc=MCA-10000 to claim your rebate (Details Below)
3. Print the rebate application at http://mcafee.4myrebate.com/?oc=MCA-10000
4. Mail in all the appropriate documents.
5. By redeeming this rebate you are agreeing to Activate and Install McAfee Multi Acess, and to
 enroll in the Auto Renewal feature of the product for the first 10 months of the the subscription.
 After the first 10 months, you are free to opt out of the Auto Renewal feature at any time.
Everything.
I have to use it
It's basically cancer. I would go get the free trial of malwarebytes! I've done tons of giveaways on the forum for that AV, it's loved :)
CPU Overclocking Database <------- Over 275 submissions, and over 40,000 views!
GPU Overclocking Database
I have to use it
can you install it on a old PC and boot it once in a while?
Why do you have to?
Hmm... didnt think of that...
but would it hurt my pc at all?
I have to use it
I don't see where it says you have to use it, you are just having it auto renewed for 10 months and can cancel the auto-renewal after that.
Please. Just don't. Just get Avast. Free for life.
Its just best to remove it and install an actual antivirus not a load of shit.
This PC was running Mcafee:
Now Serious,No,your PC will still be fine but what they are doing is just wrong and somewhat disgusting.
I have to have it on my pc for 10 months
Im only using it because having me use it for 10 months gets me a free 64 gb usb 3.0 flashdirve!
I need it to get a free 64gb usb3.0 flash drive! gives me 60$ rebate on 60$ flash drive
It gets me a free 64gb usb 3.0 flash drive, so
Let's not forget how much of a bitch it is to remove.
It actually started to take over my PC at one point.
It Cost Money. MSE/DEFENDER and Malware Bytes are perfect.
