First pc build
Go to solution Solved by ImMiles,
14 hours ago, Why_Me said:
You couldn't choose a more difficult case to cut your teeth on for a first time build if you tried. That fish tank case requires 3x120mm fans along with a AIO just to create enough air pressure to keep your components from cooking. That i9 runs on the hot side meaning that B760 board won't handle it and you will suffer thermal throttling.聽 If this is a gaming build then I would consider something like this down below. It doesn't look as niche as a fish tank case but it doesn't get any better than a conventional case with air cooling, especially for your first build. Low profile RAM so that it doesn't impede this dual tower cooler. Use the MS Key # that comes with the Windows disk to register online after you download Windows.
PCPartPicker Part List
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor 聽($339.99 @ Newegg)聽
CPU Cooler: *Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler 聽($35.90 @ Amazon)聽
Motherboard: *MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard 聽($169.99 @ MSI)聽
Memory: *Silicon Power Value Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory 聽($94.97 @ Amazon)聽
Storage: *Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive 聽($104.97 @ B&H)聽
Video Card: *Gigabyte WINDFORCE OC GeForce RTX 4070 Ti SUPER 16 GB Video Card 聽($799.99 @ B&H)聽
Case: *Phanteks XT PRO ULTRA ATX Mid Tower Case 聽($72.98 @ Newegg)聽
Power Supply: *be quiet! Pure Power 12 M 850 W 80+ Gold Certified Fully Modular ATX Power Supply 聽($99.90 @ Amazon)聽
Operating System: *Microsoft Windows 11 Home OEM - DVD 64-bit 聽($119.99 @ Amazon)聽
Monitor: *MSI G272QPF E2 27.0" 2560 x 1440 180 Hz Monitor 聽($219.00 @ MSI)聽
Total: $2057.68
Generated by PCPartPicker 2024-06-26 00:46 EDT-0400
A better look at those components.
https://www.msi.com/Monitor/G272QPF-E2
https://www.techpowerup.com/review/amd-ryzen-7-7800x3d/20.html
https://www.tomshardware.com/reviews/thermalright-phantom-spirit-120-review
https://www.msi.com/Motherboard/B650-GAMING-PLUS-WIFI
https://www.techpowerup.com/review/gigabyte-geforce-rtx-4070-ti-super-gaming-oc/31.html
https://www.techpowerup.com/review/silicon-power-ud90-1-tb/
https://www.bequiet.com/en/powersupply/4162
https://phanteks.com/product/xt-pro-ultra-black/
So can I just change my motherboard? I鈥檓 more of an intel guy.
Just now, ImMiles said:
Budget (including currency):
Country:
Games, programs or workloads that it will be used for:
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):聽
That post gives us nothing to go on.
https://linustechtips.com/topic/1574805-first-pc-build/#findComment-16450065
11 minutes ago, ImMiles said:
Sorry first time with this馃榿
Total: $2057.68
https://linustechtips.com/topic/1574805-first-pc-build/#findComment-16450087
This build runs a bit more but it includes a better quality case that's easier to work with along with a better board that includes Realtek 4080 audio codec. Replace the 140mm exhaust fan that's included with this case with the 140mm ARGB fan down below for the full effect. You can cut the cost by going with that air cooler and RAM I posted in that previous build.
CPU Cooler: *ARCTIC Liquid Freezer III A-RGB 48.82 CFM Liquid CPU Cooler 聽($134.99 @ Amazon)聽
Motherboard: *Asus ROG STRIX B650-A GAMING WIFI ATX AM5 Motherboard 聽($208.48 @ Amazon)聽
Memory: *TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory 聽($106.99 @ Amazon)聽
Case: *Lian Li LANCOOL 216 RGB ATX Mid Tower Case 聽($99.99 @ Amazon)聽
Case Fan: *Lian Li UNI FAN SL V2 77.6 CFM 140 mm Fan 聽($29.99 @ B&H)聽
Total: $2264.28
Generated by PCPartPicker 2024-06-26 01:14 EDT-0400
A better look at that board and case.
https://rog.asus.com/us/motherboards/rog-strix/rog-strix-b650-a-gaming-wifi-model/
https://lian-li.com/product/lancool-216/
https://linustechtips.com/topic/1574805-first-pc-build/#findComment-16450095
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor聽 ($339.99 @ Newegg)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler聽 ($35.90 @ Amazon)
Motherboard: ASRock B650M Pro RS WiFi Micro ATX AM5 Motherboard聽 ($149.99 @ Newegg)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory聽 ($104.99 @ Amazon)
Storage: *Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive聽 ($104.97 @ B&H)
Video Card: PNY VERTO OC GeForce RTX 4080 SUPER 16 GB Video Card聽 ($964.00 @ B&H)
Case: Lian Li A3-mATX MicroATX Mini Tower Case聽 ($69.98 @ Amazon)
Power Supply: SeaSonic FOCUS GX-850 ATX 3.0 850 W 80+ Gold Certified Fully Modular ATX Power Supply聽 ($109.99 @ Amazon)
Operating System: *Microsoft Windows 11 Home OEM - DVD 64-bit聽 ($119.99 @ Amazon)
Case Fan: ARCTIC P12 PST 56.3 CFM 120 mm Fans 5-Pack聽 ($32.49 @ Amazon)
Total: $2032.29
Generated by PCPartPicker 2024-06-26 04:17 EDT-0400
https://linustechtips.com/topic/1574805-first-pc-build/#findComment-16450184
Total: $2057.68
https://linustechtips.com/topic/1574805-first-pc-build/#findComment-16450705
CPU: *Intel Core i7-13700KF 3.4 GHz 16-Core Processor 聽($291.55 @ Amazon)聽
Motherboard: *Gigabyte Z790M AORUS ELITE AX ICE Micro ATX LGA1700 Motherboard 聽($189.99 @ Newegg)聽
Total: $481.54
Generated by PCPartPicker 2024-06-26 18:51 EDT-0400
https://linustechtips.com/topic/1574805-first-pc-build/#findComment-16450823
2 hours ago, ImMiles said:
21 hours ago, Why_Me said:
sorry but I鈥檇 like to keep the same case if that motherboard comes in ATX then that will work
Motherboard: *MSI PRO Z790-P WIFI ATX LGA1700 Motherboard 聽($190.96 @ B&H)聽
Total: $482.51
Generated by PCPartPicker 2024-06-26 22:14 EDT-0400
https://linustechtips.com/topic/1574805-first-pc-build/#findComment-16450921
