Wrong CPU Cooler?
Go to solution Solved by TatamiMatt,
2 hours ago, D-pacman said:
I'm building my first PC right now and am not sure if I got the right Liquid CPU cooler.
I'm using a MSI Pro B760-P Wifi DDR4 motherboard with a Corsair H100x RGB Elite 240mm liquid CPU cooler. Do those work together?
I just noticed the manual doesn't list LGA 1700 standoff screws.
The website does, so you should be fine.
What CPU are you running with though?
https://linustechtips.com/topic/1574804-wrong-cpu-cooler/
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1574804-wrong-cpu-cooler/#findComment-16450127
32 minutes ago, D-pacman said:
i9-12900K
Yeah that AIO should be fine then, runs a little hot for it but shouldnt be too bad
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1574804-wrong-cpu-cooler/#findComment-16450452
11 hours ago, D-pacman said:
When you say it runs a little hot, is it something I should be worried about or thinking about getting a bigger one?
If you have it already, test it first and find out, if you need one then, then go for it, but no reason to buy before you know. I reckon it will be fine
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1574804-wrong-cpu-cooler/#findComment-16451030
