I am looking for a cheap but good quality ATX sized case for under £45 ($75). It has to be able to fit a 300mm GPU. At the moment I am going with the Zalman Z3 but I wish to know if there is anything better for the price. I am wanting to spend under £45 so please do not put things for £70
https://linustechtips.com/topic/214683-atx-case-for-under-75/
Don't buy Zalman cases, please. Buy Corsair, anything Corsair. If you have 5 dollars you can buy the 330R, great case IMO.
Case: Corsair Carbdie 330R Motherboard: Gigabyte GA-970A-DS3P Asus Z97-A CPU: AMD FX-6300 i5 4690K 3.5 GHZ + 212 EVO GPU: ASUS GTX 760 DirectCUII Ram: Corsair Vengeance LP 8gb (2x4gb) HDD: Seagate Barracuda 1TB PSU: Corsair CX500M
Monitor: AOC Q2963pm 29'' 21:9 IPS Mouse: Mionix Naos 8200 Mousepad: Mionix Sargas 320 Headset: HyperX Cloud Keyboard: Corsair Gaming K70 RGBIKEA Headset/Headphone Holder
https://linustechtips.com/topic/214683-atx-case-for-under-75/#findComment-2937713
https://linustechtips.com/topic/214683-atx-case-for-under-75/#findComment-2937714
Corsair Carbide 300R
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/214683-atx-case-for-under-75/#findComment-2937723
I am looking for a cheap but good quality ATX sized case for under $75. It has to be able to fit a 300mm GPU. At the moment I am going with the Zalman Z3 but I wish to know if there is anything better for the price.
NZXT Source 340
The case I would get hands down for under 100 bucks right now
"Rawr XD"
https://linustechtips.com/topic/214683-atx-case-for-under-75/#findComment-2937751
http://www.corsair.com/en-us/graphite-series-230t-windowed-compact-mid-tower-case-battleship-grey
You can also get it in orange or black.
I have the 230t (black) its a nice case, quite a bit of cable management room, though I would have liked to see rubber grommets for the cable management cutouts.. (You can probably get some on ebay or something for it if you want them)
https://linustechtips.com/topic/214683-atx-case-for-under-75/#findComment-2937765
whats wrong with zalman, the z1 and z3 are horrid, whats your problem with zalman other then that
Listen if you care.
https://linustechtips.com/topic/214683-atx-case-for-under-75/#findComment-2937820
Quality is meh, warranty is meh, support is meh, everything is meh.
https://linustechtips.com/topic/214683-atx-case-for-under-75/#findComment-2937889
At the price of zalman produces id like to see you do better, im not being hostile. Anyways im not an advocate of expensive cases most of the time, i prefer more about appearance mostly as customers just look at a case and they care about what processor, ram or storage.
As a result things like the zalman r1, coolermaster n400 or the source 210 things like those cases look nice and are cheap, quality doesnt really matter but i guess thats because i have a business while others are building for themselves, anyways your opinion is sound zalman dont have amazing anything apart from price and a stupid amount of fans
Listen if you care.
https://linustechtips.com/topic/214683-atx-case-for-under-75/#findComment-2938052
Ok, that might be true, but me no like ze Zalman.
https://linustechtips.com/topic/214683-atx-case-for-under-75/#findComment-2939154
