how do i stop bittorrent from automatically starting up?
Go to solution Solved by Levent,
Just now, Indian pc builder said:
nothing there
"Preferences"
it doesnt show up in startup apps
Imagine everything i have written in a Linus Voice/ linus tone (Spock live long and prosper gif here ,idk why tho, i guess i just want to say that i like star trek and am waiting for new seasons of the ongoing shows), But seriously, a lot of what i type only makes sense when said in a Linus tone from an older ltt video (circa 2017-2019 & now 2024-onwards) basically before he got a beard and a lot of it should make sense even in a Linus with a beard face.
also note as per the latest typing test on my laptop, my accuracy is 69%
I'm not weird/creepy, I'm just observant I have ADHD and am not on any meds for it.
Check in its options.
nothing there
nothing there
"Preferences"
nothing there
Ctrl-P should show something.
I edit my posts more often than not
nothing there
Click "Preferences" and look around in the window that appears.
If you still don't find anything, you can disable startup applications from Task Manager or MSCONFIG.
https://techcommunity.microsoft.com/t5/windows-11/how-to-disable-startup-programs-in-windows-11-3-ways/m-p/3249863
1 minute ago, Levent said:
"Preferences"
i have been looking for that setting for a while and havent found it till now, i may need to get my eyes checked
2 minutes ago, Indian pc builder said:
nothing there
Task Manager, Startup, it might show up there. There's also a menu if you search "Startup Apps" in Windows.
Ryzen 7950x3D PBO +200MHz / -15mV curve CPPC in 'prefer cache'
RTX 4090 @133%/+230/+1000
Builder/Enthusiast/Overclocker since 2012  //  Professional since 2017
7 minutes ago, Levent said:
"Preferences"
dammit didnt work
Edit : just restarted and now it did work
checked not there
dammit didnt work
checked not there
Win+R then type shell:startup
If its not there, then I guess uninstall it and reinstall it clean.
It's the second thing in that menu.
3 minutes ago, Indian pc builder said:
checked not there
Use the "Startup" tab in Task Manager.
hence why i need to get my eyes checked
Just now, mariushm said:
Uninstall it, and install qBitTorrent or some other client ... qBitTorrent is very good.
i'll look into it
