wifi faster than ethernet?
Solved by Alex Atkin UK,
3 hours ago, Melon_Wolf1 said:ah yea sorry missed that one, i exclusively use logitech lightspeed mice and dont percieve a difference between wired/wireless lol
Yes i have swapped the cable to a brand new cat 6 cable with no change, drivers and bios are up to date including on both the router and ISP hardware
Oh I notice it has Killer software, is that installed? That often lives up to its name and kills the speed.
