5W/mK conductivity thermal paste good for a 105W thermal power cpu?
Solved by RONOTHAN##,
1 minute ago, Fat Cat11997 said:You said earlier that it's important to get a reputable brand, and I think it is. It's made by Corsair and on Microcenter has 60 reviews and an average of 4.7 stars
Then it's probably good enough. I think I know the paste you're referencing, TM30, and while it's not amazing it's good enough. The difference between the good pastes is usually 2-3c at most, so you will be fine with it.
That said, since it sounds like you're buying a new computer, the CPU cooler will come with thermal paste that's also good enough, so you might as well use that.
