I kinda need help
Go to solution Solved by filpo,
2 hours ago, genshin said:
my budget is 350€
right now i have a laptop with ryzen5 pro 2500u
1080P
Estonia
for gaming most of the time
Look for a used 3600 (with stock cooler) for around 50 euros, used b450 for 50 euros, 2x8gb 3200 ram new for 35 euros, 1tb NVME for 60 euros new (512gb for 40 if you don’t need that much), psu like an a550bn for 50 euros, used case for 30 euros and slap in your 1050 ti
11 minutes ago, genshin said:
Hi guys i have a gtx 1050ti and idk if i should put in a office pc or a custom bulid.
What's the psu wattage in the office pc? Does it have any 6 pin connectors?
My guess is the office pc will need it most, but if it is an office pc and you're using it for 'office' things you won't be gaming much on it
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1568685-i-kinda-need-help/#findComment-16395582
Is it for you or do you sell PCs?
1050 ti is decent for both, weak for gaming but good enough for a selection of specific games, not just old ones either.
As for office PC it's got plenty of power, especially for basic tasks.
current PC:
PC configs I used before:
https://linustechtips.com/topic/1568685-i-kinda-need-help/#findComment-16395587
I just want plan ahead cuz im trying to get a decent pc for games
https://linustechtips.com/topic/1568685-i-kinda-need-help/#findComment-16395617
What's your budget for a new build?
Have you got a current pc and if so what are the specs?
What resolution will you be gaming at?
What country are you in?
What will you be using the pc for
Total: £1040.95
https://linustechtips.com/topic/1568685-i-kinda-need-help/#findComment-16395621
my budget is 350€
1080P
Estonia
https://linustechtips.com/topic/1568685-i-kinda-need-help/#findComment-16395907
my budget is 350€
1080P
Estonia
Total: £1040.95
https://linustechtips.com/topic/1568685-i-kinda-need-help/#findComment-16395962
