Floatplane DOES NOT provide users with better audio quality
AHPanda
Go to solution Solved by Divritenis,
Seems that audio does indeed differ from FP to YT. From YT I can download 48kHz stream that essentially has no LPF. 44.1kHz stream has LPF at around 16kHz. FP is around 14.4kHz, same as in the reddit post.
FP
YT
Luke and his team should look into this. I'm not going to brand this as lying, probably more like something that has changed since initial comments on WAN about it.
last time I checked nobody cares
better video and youtube audio compression is garbage good enough for me
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
Sigh, here we go again.
As a floatplane subscriber I would like to know what the money I am paying is being invested in, as they advertised it's partially to maintain stuff like a higher quality audio. Especially when in those same videos they have said it doesn't cost a whole lot over lower bitrates.
This just seems another case of we're going to churn out quantity over quality.
Edit, seeing as you edited your post;
The point isn't what is good enough for /you/, the point is they went out of their way to advertise that the quality and bitrate is better which in essence is false advertising at worst and misleading in the best case scenario. Both are bad.
I'm applying Ikea spelling, meaning you get most of the words and letters, then it's up to you to assemble them correctly! 👍
3 minutes ago, AHPanda said:
False advertising is okay to you?
To play devil's advocate, unless I'm misunderstanding something, the audio quality is still better than YouTube's. It's not hugely better, and it's not what I would call "high bitrate" for audio, but "higher audio quality" doesn't mean "excellent audio quality."
In the same way that "up to 3,500 MB/s" is true for an NVMe, "higher audio quality" is still true for Floatplane, even if misleading.
yes
System Specs
Peripherals
<Razer Mini>
Just now, SignatureSigner said:
yes
If you think false advertisements or misleading claims are okay from a company that constantly states they are here to defend consumers and do the right thing then please stop posting now, you are adding nothing to the benefit of the discussion or the company in question.
*Some in the LTT community looking for attention from senpai on the forums*
Shes A Witch GIFs | Tenor
Ryzen 7950x3D PBO +200MHz / -15mV curve CPPC in 'prefer cache'
RTX 4090 @133%/+230/+1000
Builder/Enthusiast/Overclocker since 2012  //  Professional since 2017
I wanted a duck...
System Specs
Peripherals
<Razer Mini>
I'm no audio/videophile so I can't say you're right or wrong, but it is an interesting point to bring up. But there are still other issues in the topic like VAT not being properly charged in EU (which is mandatory) so it's possible they're dodging taxes.
Damn your taxes
Thought-this-was-america GIFs - Get the best GIF on GIPHY
4 minutes ago, SignatureSigner said:
yes
Indeed, we already tired of all this drama (not just from Floatplane), many other premium platform have similar allegations regarding false advertising, but for me personally, If I already felt that the main features I wanted (especially the content quality itself) is good, I wouldn't bother to think I've been ripped off because small insignificant things
Call me an ignorant, because I am. And I definitely doesn't defending Floatplane on this, it is what it is.
LENNYYYYYYYYY!!!!! WHERE R U BUOYYYYY??????
  •  Laptop:
    • Current
      • Spoiler
        Lenovo ThinkPad X1 Yoga Gen 8 | i5-1335U | 16GB LPDDR 6400MT/s Soldered | WD SN810 1TB NVMe (Win11) | 14 inch 1200p IPS 500 nits panel | Intel AX211 | 65W USB-C PD adapter | Aliexpress DIY Thunderbolt 3 eGPU dock with JieShuo RTX 3060M 12GB
    • Retired
      • Spoiler
        Heavily modified Lenovo ThinkPad T480 | i7-8550U | 2x 16GB Teamgroup DDR4 3200MT/s | Custom FCBGA 595 to Oculink 2.0 @ PCIe 3.0 x4 (using removed nvidia MX150 dGPU pinout) | 14 inch 1080p IPS 350 nits panel | 7 Row classic keyboard mod (from T25) | 512GB Samsung PM981a NVMe SSD (Win10) + 256GB WD SN520 2242 NVMe SSD (Manjaro; on WWAN slot) | Intel AX210NGW | 65W USB-C PD adapter  | Oculink 2.0 to PCIe x16 DIY dock eGPU with JieShuo RTX 3060M 12GB
  • Workstation:
    • Current - Repurposed as Homelab Dev Server
      • Spoiler
        AMD EPYC 9454P 48C/96T | Tyan Tomcat HX S8050 (S8050GM2NE) Socket SP5 | 8x32GB (256GB) Kingston Fury Renegade DDR5 4800MT/s RDIMM | Colorful iGame RTX 4080 Advanced OC (windows VM) | PowerColor RX 6600XT Fighter (MacOS VM) | 2x Intel Optane M10 64GB (RAID 1, Proxmox) | 4x Samsung 980 Pro 1TB (RAIDZ1, VM storage) | Nvidia Mellanox ConnectX-4 LX 25Gb SFP+ PCIe x8 (MCX4111A) | Seasonic Prime TX 1600W | Thermaltake Core W100 case | Enermax LIQTECH TR4 II 280mm AIO (SP5 Kit) |8x Deepcool TF140S Fan
    • Retired
      • Spoiler
        Intel Xeon E5-2650v3 10C/20T (locked all core 3GHz) | Dell ALienware Area 51 R2 Motherboard (MSi MS-7862) LGA 2011v3 with modded BIOS (ReBAR enabled) | 4x16GB (64GB) SKhynix ECC LRDIMM 2666MT/s Quad Channel | Colorful iGame GTX 1070 Flame Ares U-TOP | Samsung PM981a 512GB NVMe SSD (Win10) + TeamGroup MS30 M.2 SATA 512GB (Manjaro) | Mellanox ConnectX-3 OCP 2.0 NIC (with PCIe adapter) |  Thermalright AXP-100H Muscle CPU cooler (hacksawed to work with LGA 2011v3) | PowerUp Raptor 1633 case + 6x Deepcool RF-120FS case fan | IndoCase 500W 80+ Silver PSU (Rebranded & binned up Gamemax GM-500).
  • Homelab AIO server:
    • Current - Repurposed as Backup server
      • Spoiler
        AMD Ryzen 9 3900 (OEM CPU, got it from AliExpress) | Asus Prime B550-Plus AC-HES | 4x16GB (64GB) Samsung DDR4 3200MT/s ECC UDIMM | 2x Intel Optane M10 64GB (RAID1, TrueNAS Scale) | 6x Seagate SkyHawk 8TB (Bulk storage; RAID Z1; Alhua rebranded drive) | Asrock ARC A380 6GB Challenger OC (Terminal + Transcoding GPU) | Mellanox ConnectX-3 OCP 2.0 NIC | Deepcool Gammax C40 (dual fan) | IndoCase IC4008 4U rackmount case + 5x Deepcool XFAN120 + 2x Deepcool XFAN80 | IndoCase 800W 80+ Silver PSU (Rebranded & binned up Gamemax GM-800) | Samsung Galaxy S10+ 5G (5G backup uplink for Router VM).
    • Retired
      • Spoiler
        Intel Xeon E5-2695v3 14C/28T (force dynamic turbo all core up to 3GHz) | Huananzhi X99-TF-Q (Q87 chipset) LGA 2011v3 with modded BIOS (ReBAR & all core turbo enabled) | 4x32GB (128GB) Samsung ECC LRDIMM 2133MT/s Quad Channel | Nvidia Quadro NVS 295 (via M.2 E key riser; for basic display) + Dell GTX 1070 OEM (transcoding GPU) + Sapphire Pulse RX 470D 4GB (MacOS Ventura VM) | 2x Kingston A400 120GB (mirrored; TrueNAS SCALE) + 6x Samsung PM981a 1TB (VM storage; RAID Z1) + 7x WD Purple 4TB (Bulk storage; RAID Z1) | Mellanox ConnectX-3 OCP 2.0 NIC (with PCIe adapter) | Alseye M90 CPU cooler (hacksawed to work with LGA 2011v3) | IndoCase IC4008 4U rackmount case + 5x Deepcool XFAN120 + 2x Deepcool XFAN80 | IndoCase 800W 80+ Silver PSU (Rebranded & binned up Gamemax GM-800).
  • DIY Router:
    • Current
      • Decommisioned, current router system is running on current AIO Homelab server as VM (Modemsofmen ROOTer GoldenORB OpenWRT 22.10).
    • Retired
      • Spoiler
        HP EliteDesk 800 G1 SFF Prebuilt | Intel core i5-4460T | 4x 4GB Samsung DDR3L 1600MT/s UDIMM Dual Channel | 1x Kingston A400 120GB (ROOTer GoldenORB OpenWRT 22.10) | Mellanox ConnectX-3 OCP 2.0 NIC (with PCIe adapter) + Realtek RTL8125 2.5GBe PCIe NIC + Intel i210 SFP PCIe card with Mikrotik SFP ONU module (for WAN, my default ISP modem sucks) + Fibocom L860 4G modem (with USB 3.0 adapter, for WAN redundancy).
  • Desk setup:
    • Spoiler
      viewsonic VA2732-H 27 inch + VA2215H 22 inch (portrait) 1080p 75Hz IPS monitor | DIY sound system with 2 50W DIY bookshelf speaker | Senheisser HD 600 Headphone | Keychron K1 SE keyboard (Low profile Gateron brown) | Lenovo ThinkLife WLM210 mice | Samsung Galaxy S8+ (used as a Webcam LOL).
Your response is why corporations think they can get away with things like this.
I mean, I get it. For you, the things they lied about don't have any value to you. HOWEVER. To others, it may be and in general deceptive. If you are a potential buyer and you are contemplating to buy a subscription. You may be swayed by the extra features that may not end up being the case.
The fact that some of the comments about this show it's not important, makes it obvious to me LMG thinks the same and can just use this for extra selling points that shouldn't be selling points. It's wrong, even if you may not care.
Damn, I will have to listen to the christmas album when it come out in sub-optimal audio quality.
But seriously those claim are 6mo to 4yo, and there might have been change to deal with the flood of new subscribers during the channel hack.
To me video quality is definitely better than youtube, but I don't know much about audio quality.
Newegg used to not charge sales tax, which is something the state of PA asks you to report if a business doesn't charge it.  Of course I'm not gonna tell on them, I don't have to pay sales tax so I'm fine with that. As long as not paying VAT doesn't get the consumer in trouble, it doesn't matter on our end. But LMG could face serious fines, or worse, if proven to be true. As for Newegg, I haven't used them in a few years so idk if that's still true (I don't trust the way they package and ship items anymore).
Obviously, for consumers this is better. But it does open up more lines of avenue about things LMG are doing to cut corners. Which is something Linus is known for.
Look man, let's talk about the audio thing in the practical sense. From the reddit forum analysis itself, unless you using audiophile DAC and headset equipment, both compared data is doesn't matter that much to the general consumer. And again, FloatPlane is not just providing LMG content, it's also having other creators content inside it, so if they upload their content, both audio and video source is the one to be a reference point for the final stream quality.
About the deceptive marketing thing, remember the whole fiasco surrounding GTX 970 marketed having 4GB of VRAM? which is heavily marketed by NVIDIA as one of big selling point. NVIDIA caught red-handed that the remaining 512MB of VRAM is actually running slower than the rest 3.5GB of VRAM. And you damn sure everyone caught the smoking fire from that fiasco. But in the end of the day? even as of last year, GTX 970 is still considered a well investment for people that buying it.
It's not about one deceptive marketing that made a platform or any product bad, but how the overall value and quality to each patron/consumer is matter. Again, I hate that many corporation "getting away with it", but also, again, it is what it is.
  •  Laptop:
    • Current
      • Spoiler
    • Retired
      • Spoiler
  • Workstation:
      • Spoiler
    • Retired
      • Spoiler
      • Spoiler
    • Retired
      • Spoiler
  • DIY Router:
    • Current
    • Retired
      • Spoiler
  • Desk setup:
    • Spoiler
7 minutes ago, TimedPing said:
... but also, again, it is what it is.
And there's the problem. That line says everything you need to know about consumers these days.
Just to go back in time a bit. Back in te 30's, several lightbulb factories set up an arrangement to purposely downgrade the quality of their product so they wouldn't last longer than x amount of hours. The public backlash was "it is what it is". That was +90 years ago, nothing changed.
I know it's a different line of goods entirely, but the principles are applied everywhere.
Game devs lying about features, quality, graphics. Electronics companies lying about the lifetimes of their goods. Food producers lying about being 'bio'.
They do it because consumers let them. Your response falls exactly in line with what those corporations want.
But I'm going off-topic here.
(https://en.wikipedia.org/wiki/Phoebus_cartel if you're interested about the lightbulb thing)
-moderated content removed-
Why not send this to Floatplane support and ask why your audio quality isn't what you expected?
It could be as simple as an editor making a mistake when exporting the video, and I am sure they would be happy to sort out any issues you are having.
 Almost as cool as my temps
your understanding of the Phoebus cartel is wrong. It was not purposely downgraded, it was more efficient
What is better
a 10 cent lamp that makes 1k lumens at 60 w for 1000 hours or
a 10 cent lamp that makes 1k lumens at 80W for 2500 hours or
two 10 cent lamps that make 500 lumens each at 40w that last 2500 hours?
for your wallet, it is STRONGLY the first one. it uses 150 kw/hours (60*2.5 to make it last 2500) while the inefficient long-lasting lamps use 50kw/hours more (not to mention the additional 20W of heat load on the house that you need to cool, per light fixture).
Finished reading about it on Reddit seconds ago.
Waiting for some technical explanation on this one. Things can get messy in technical stuff really fast.
This font is amazing.
The GTX 970 fiasco is quite a bad example to bring up for your argument, because Nvidia was successfully sued and had to pay $30 to every affected US customer over it. I don't know where you're getting your "considered a well investment" metrics from, but the issue is probably the most well known problem of any GPU ever released and often when that graphics card is brought up, does the VRAM issue also get brought up at some point in the same breath.
23 minutes ago, Benergy said:
Ah, yet another post pushing an agenda, from someone who only joined the forums this week.
In fairness the subreddit, where the post is actually from, has been in "community only" mode for the past few days. I believe the bar for entry is 50 karma on that specific subreddit.
So regardless of the age of the account on these forums, at the very least the OP on Reddit must have either been around a bit or posted something of some substance in the past.
Obviously no idea what that was, but we can at least rule out that they've jumped on the bandwagon right now, or their post would've been auto-deleted on the sub.
Moreover they're clearly a Floatplane subscriber, so to my mind they are a little different to the look in audience from r/all and the like.
That is actually not a good analogy. The physics behind light bulbs was pretty well understood at that time. You just have to make a choice between efficiency and longevity. The hotter/brighter you can drive the wire in the light bulb, the more energy will be output in the visible spectrum. So no one downgraded their products, if you want proof of that, the cartel in question is long disbanded, but all light bulbs still follow all the same guidelines (I think it was 1000h on time). If you want a video about it ->
On the other hand, I don't think this is okai from floatplane. They obviously advertised better quality and now aren't delivering it anymore. They probably just unified their floatplane and youtube production, so that they don't have to render separate files for each website ... Floatplane is technically capable of delivering higher audio quality, which is also portrait in the reddit post. I do hope LMG responds to this though.
