Camera has really bad color accuracy when at a distance, but its fine when up close, and out of focus.
I think it's the difference between the dynamic range of what your camera is capable of capturing versus the dynamic range of human vision. It can't process the high brightness of the RGB unless you lower the image exposure (and bring down the brightness of the whole room).
I think if you really want to film RGB lighting, you'll have to BRIGHTLY light up the whole room. That way you bringing down the exposure will make everything look natural.
On 5/23/2023 at 9:36 AM, My_Computer_Is_Trash said:Yes, it removed the white problem. But when you turn it back up during editing, the problem gets fixed, and is WAY more color accurate. I also noticed that if you take a picture with the exposure at normal, it looks white, but the color gets fixed in post processing. I took a screen capture of what I mean. The screen capture is below.
Yes, the post-processing is what fixes the image beyond what the dynamic range of the sensor is able to capture.
