How much to spend on a router for a small home?
On 4/15/2022 at 3:53 PM, Rayzioz said:so am i having a bandwidth issue or latency issue if i can't simultaneously watch and play on multiple devices at once? on the smart tv the video just stops and buffers so it sounds like a bandwidth issue but is that caused by router not being able to provide enough bandwidth to multiple devices?
in that case, why did this problem not occur once when we were on the faster speed internet from the ISP?
will start reading about the cpu/ram/software in these routers and see if i can find the difference in them. cheers.
I'm more thinking towards CPU overload on a cheap (altho undisclosed) router. Maybe not having the wireless bandwidth.
As every device wirelessly connected will make the whole slower, as they all will have to wait on one another. Which can introduce latency.
But most likely its a combination of things.
However it is indeed weird that going from 250mbit to 100mbit gave so much troubles, it really shouldn't. (at least not like that).
I would first check Speedtest.net and see what the speeds are, and also the latency.
And just to be sure also test on Fast.com which is Netflix's bandwidth test site.
(I currently have a 100mbit connection and i can watch even 8K Youtube videos with no problem. so 4K or lower should surely work too.)
2 hours ago, SupaKomputa said:250mbps is the bandwidth allocated from the ISP, it will be shared to all devices, so if 1 of your device using 150mbps, the rest should only use max 100mbps.
A 1080p netflix will cost 20-30mpbs while 4k should be around 80.
Distance and obstacles is also key for better signal.
If i may correct you on the numbers. (altho these are averages, they can be higher or lower).
4K is around 15Mbps
1080p around 5mbps.
This is Netflix and thus has a relatively low bit-rate, and high codec compressions. (compared to things like Blu-ray)
Source: https://help.netflix.com/en/node/306
