The case IS the cooler?? - Streacom DB1 Max Fanless PC
ColinLTT
The Streacom DB1 Max is a teeny tiny case with BIG dreams – can it FANLESSLY dissipate the 65 watts of heat it claims?
sadly its just 40mm too thick for my use-case [mediacenter pc]
otherwise its quite the nice case
║__________________║ hardware_____________________________________________________ ║
║ cpu ______________║ ryzen 9 5900x_________________________________________________ ║
║ GPU______________║ ASUS strix LC RX6800xt______________________________________ _║
║ motherboard_______ ║ asus crosshair formulla VIII______________________________________║
║ memory___________║ CMW32GX4M2Z3600C18 ______________________________________║
║ SSD______________║ Samsung 980 PRO 1TB_________________________________________ ║
║ PSU______________║ Corsair RM850x 850W _______________________ __________________║
║ CPU cooler _______ ║ Be Quiet be quiet! PURE LOOP 360mm ____________________________║
║ Case_____________ ║ Thermaltake Core X71 __________________________________________║
║ HDD_____________ ║ 2TB and 6TB HDD ____________________________________________║
║ Front IO__________   ║ LG blu-ray drive & 3.5" card reader, [trough a 5.25 to 3.5 bay]__________║
║ OS_______________ ║ Windows 10 PRO______________________________________________║
Heatsinks on the outside.. Damn, i want that.. but the size of my actual pc..
Useful threads: PSU Tier List | Motherboard Tier List | Graphics Card Cooling Tier List ❤️
Baby: MPG X570 GAMING PLUS | AMD Ryzen 9 5900x /w PBO | Corsair H150i Pro RGB | ASRock RX 7900 XTX Phantom Gaming OC (3020Mhz & 2650Memory) | Corsair Vengeance RGB PRO 32GB DDR4 (4x8GB) 3600 MHz | Corsair RM1000x |  WD_BLACK SN850 | WD_BLACK SN750 | Samsung EVO 850 | Kingston A400 |  PNY CS900 | Lian Li O11 Dynamic White | Display(s): Samsung Oddesy G7, ASUS TUF GAMING VG27AQZ 27" & MSI G274F
I also drive a volvo as one does being norwegian haha, a volvo v70 d3 from 2016.
Reliability was a key thing and its my second car, working pretty well for its 6 years age xD
Linus sponsor spot: I’m going to guess you’re not an accountant…
Me: sad accountant noises as I review IT controls for public companies.
you can hear anthony is glad he doesn't need to build in the case again... until the next episode
Another year, another fire... oh wait, oh no?!?
1 hour ago, Somerandomtechyboi said:
The case : has good heat dissipating capabilites while being passively cooled
The exterior of the case when you touch it :
Edited by Quackers101
Could you toss on some stick-on passive heat sinks for the VRMs on the Mobo to make this work with AM4?
Given the inclusion of that serial port I very much doubt gaming was the intended use case of this mobo - a lesser chip would perform just fine, and there are numerous applications where this can be used that don't need a dGPU. Fanless systems are really meant where the air can be very contaminated like in a workshop or dust is a serious problem.
You could try some stick on passive heatsinks for the VRM's but again this mobo was designed for something else, otherwise they would have included a more robust VRM cooler with it.
The fact that they include that 2nd HDMI port tells me this is aimed more for use as a POS or kiosk application, displaying static graphics, or for digital signage. Many custom LCD's now have HDMI fitted as their interface as well, so it's not just for plugging in a PC display. This "may" work as a HTPC pulling content off a NAS, but I'd limit that to 1080p30 - you would need beefier specs to run a 4K TV, and there are better fanless HTPC boxes out there.
I know you have been buying things from chinese shops, but not every shop ships to Canada...  Maybe they would make exception for LTT.
Looking at bigger case from https://www.caseking.de/en/cases-and-modding/pc-cases/aluminium-cases#search:query=fanless+cases&tplview=desktop
What I am looking for is a case that could run AMD APU with RDNA2 without any fans. Problem is such APU wattage is yet unknown, so I am waiting for it. Obviously proper size RAM. No moving parts means longevity, at least I hope so. And no noise is a huge bonus.
It would be nice for change if you review something that we Europeans can actually buy without messing with customs.
This video was a little off I think.
Fanless PCs for consumer use are meant for light applications; web browsing, word processing, and media consumption.  They really aren't ever meant to be used for anything remotely taxing on the system.  Spending 25% of the video trying to stress test it isn't really the right way to evaluate a fanless PC.  The testing should match its use-case.  A quick blurb about how cpu intensive workloads are really outside the bounds of what it was meant to handle with the thermal data as emphasis would have been more appropriate, while focusing on what it can provide; a quiet, comfortable, and tidy computer space for people who just have basic needs for a computer. Maybe even a little history bit on how fanless PCs really stem from the industrial sector in environments where dirt, dust, or vibration can destroy fans in a matter of months but the overhead of constant fan replacement is not feasible.
I also think the cpu selection for this was improper.  I looked up this case on the Streacom website and it says this about it:
Quote
Is it safe to use a CPU with the same maximum specified case TDP?
In the past, CPU TDP was a measure of the maximum required cooling performance of a cooler to maintain the normal operating temperature of the CPU. With the advent of performance “boosting” technologies, the specified TDP is no longer an accurate representation of the required cooling performance, but more a baseline reference. When these technologies are enabled, CPUs can boost well above the specified TDP rating and they try to take advantage of thermal overheads. It is therefore important when choosing a CPU for a fanless case to consider the actual maximum TDP that the CPU can output. Wherever possible, aim for a CPU TDP that is below the case TDP rating or consider BIOS settings that will limit the CPU to the maximum TDP supported by the case.
Neither was done for the video, even though the video acknowledges issues with TDP ratings from manufacturers.  A matching TDP processor was selected without adjusting the bios to ensure it conformed to the case's rating...and then it was stress tested.  It just feels out of touch.  This warning is listed on all of Streacom's fanless PCs, and just a cursory look into fanless PCs should have indicated this issue would immediately be a problem.  Generally you would also buy some thermal pads and affix static heatsinks to the VRMs to aid them.
I understand this was a video review of a specific product and that the audience here mostly enjoys the 'ermagerd can it game or edit?' template, but generally you need to put the product in the right context so people understand what it is trying to accomplish.  You don't buy a Golf Cart and then complain it can't match performance metrics of a proper automobile, but that is pretty much what was done here.
Anyways, Anthony did a good job.  Always enjoy watching his videos.  Thanks for the content!
Keep Learning
2023-Present: Senior Technical Advisor
2020-2023: Communication Infrastructure Engineer & Project Manager
2015-2020: Senior Systems Administrator
2013-2015: Server/Network Architecture Engineer
2011-2013: Systems Administrator
You folks should check out the Akasa Euler next. I think it's a better design for passively cooled THIN min-ITX systems. See my HTPC "BlackBox" in my sig.
BabyBlu (Primary):
  • CPU: Intel Core i9 9900K @ up to 5.3GHz, 5.0GHz all-core, delidded
  • Motherboard: Asus Maximus XI Hero
  • RAM: G.Skill Trident Z RGB 4x8GB DDR4-3200 @ 4000MHz 16-18-18-34
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2070MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 10 Pro
Roxanne (Wife Build):
  • CPU: Intel Core i7 4790K @ up to 5.0GHz, 4.8Ghz all-core, relidded w/ LM
  • Motherboard: Asus Z97A
  • RAM: G.Skill Sniper 4x8GB DDR3-2400 @ 10-12-12-24
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Corsair Vengeance C70, w/ Custom Side-Panel Window
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair AX760
  • Display: Samsung C27JG56 27" 2560x1440 144Hz Freesync
  • Cooling: Corsair H115i RGB
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
Hey Colin, had to make an account since I don't socialize with media.  I did enjoy this video, lots of comments about the serial port.  Would be interesting if Anthony were to do a show on those devices and their application.  I know from entry level JAVA about 15 years back programming the serial port to student designed sensors was a common element in many university programs but I'm not as aware of industry or medical or financial uses/applications as much.  I do wish AMD had done a better job in pushing out support for this chip set, like I said in a previous video, it isn't that bad a deal when reviewed by folk, and Anthony didn't over state it at all as well.
I wonder how this compares to a Mac mini. The mini doesn't need a power brick, so maybe that's a win. But workstation, creative and productivity tasks could be compared.
Is there a reason that some add-on heat sinks were not considered for the 5700G ITX board?
https://www.amazon.com/DGZZI-Heatsink-9x9x12mm-Conductive-Adhesive/dp/B0988Z1JT3/
Those or something similar ought to be able to shed a good deal of VRM chip heat even without airflow. I used a much much much smaller set of stick-ons to resolve some VRM heat issues in a Lenovo Tiny with no internal airflow to the VRM.
  • 3 weeks later...
Could something like this with the Ryzen 5 5600G be good for a HTPC since it is silent? I just wish we could get a motherboard with multi-gig Ethernet but I guess you could just use one of the USB ports with an adapter.
