Tips for running a server at home?
2 minutes ago, KhakiHat said:I haven't experienced any issues with needing IP protection, I was just curious if it is a precaution I should take just to be on top of things in general.
Should be fine if its just your friends.
I can look into running a hypervisor like proxmox while running a VM. Would running a VM be necessary if it is at such a small scale? Or is just for the separation between PC resources and vulnerability?
If ind its just easier to manage. You can make snapshots and roll back. And you won't have conflicts as each server is in its own vm.
3 minutes ago, KhakiHat said:
And fair enough on wattage concern. You're probably not wrong, I think the Celeron's max wattage is 58W but you'd probably really have to push it even get that.
Its idle is much lower, without many drives this system will easily idle at sub 20w from the wall
4 minutes ago, KhakiHat said:
I planned on bottle-necking the server PC with around 200MB/s for down speeds just to keep other devices on my network running smoothly. My up speeds are around 39MB/s.
Those upspeeds should be fine here.
I think your getting bytes and bits confused. Your network cards is a gigabit, so the fastest file copies you can get are about 120mB/s
