fan configuration AIO Push or Pull air? Intake or exhaust?
7 hours ago, NorKris said:just turn the top fans to intake and ur fine and its the easiest
15 hours ago, thrasher_565 said:rip sli...
the way i see it the aio only get 1 fan of fresh air flow and the gpu exhaust in to the aio... i would put the aio and intake. or you can put the aio on top and have bottem top intake and side back exhaust. dont no witch will be cooler thow. the intake from the top should help the vrm temps
as for sli temps nothing you can really do. only water cool them.
On 8/24/2021 at 12:21 AM, narrdarr said:I had mentioned this earlier and still agree. although rgb fans are p12s too. personally think the rgb fans would look better at the top as performance would be the same.
On 8/23/2021 at 9:06 PM, WoodenMarker said:Move the rad to the top as exhaust with P12's. You can flip the RGB fans at the side for intake.
On 8/23/2021 at 6:30 PM, ADarkBard said:I might be crazy here but I think you have too many fans. There's no place for the air to go efficiently.
On 8/23/2021 at 3:40 PM, NorKris said:if ur saying im wrong with all the data out there telling you that push is 1-3c better than pull...
btw i did a push vs pull on a QL120 6c diffrence
Hi everyone, I found the optimal solution:
1. Rad on top, fans pulling, exhaust
2. Bottom intake
3. Side Exhaust
4. Rear intake! Sounds strange, but this gives the rad cold air.
The side exhaust now without resistance from the rad sucks the GPU air out so well I'm actually experiencing a ~15 degree drop in GPU temperatures all around...honestly very surprised. At idle right now the GPUs are ~33 and ~39. Ambient is about ~22. This is with the default fan curve, meaning the lower cooler card's fan isn't spinning at all while the top as at it's lowest (30%).
