How do I connect my PC to Fiber with ethernet?
WestTexan
Go to solution Solved by Dedayog,
Just now, WestTexan said:
Wired connection is faster/more reliable though,right? Also, I don't have wifi on my PC
Buy wifi?   A USB wifi adapter is cheap.  Get Powerline, but that's not the best way to go, IMO.
I mean, not sure what you want from us.  It's internet, you connect in only a few ways.  Pick one.
1 minute ago, Generic Username said:
WiFi isn't as reliable as CAT cable
Wifi is fine, millions of people use it daily to game and stream.
Fiber is installed in the kitchen/lounge. My room is next to the kitchen. Is it possible? Kitchen on the left,room on the right
You can also connect via wifi too.  It's the same as any other internet setup.
The routers/modems have the same connections regardless of ADSL, Cable, Fiber, etc.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
3 minutes ago, Generic Username said:
Using an enthernet cable
lol,made me chuckle
but if the modem or router,I dont know the devices is in the kitchen and my pc is in another room.How would I use an ethernet cable? Do I have to buy a really long ethernet cable and have it run on the walls to my PC?
OnePlus:
Other Tech:
Just make sure your WiFi solution has enough bandwidth to saturate the bandwidth given by your ISP.
i.e. if it is a 20 mbit connection any $10 adapter will work, if you have a 500 mbit connection try looking into 5ghz/wifi 6 if your router supports it.
example of a cheap adapter:
https://pcpartpicker.com/product/CG9KHx/rosewill-wireless-network-card-rnxn250pce
example of a more expensive adapter:
https://pcpartpicker.com/product/zQqPxr/edup-ep-9636gs-bl-pcie-x1-80211abgnacax-wi-fi-adapter-ep-9636gs-bl
Yeah, it is much more reliable and fast because it doesn't have to go through the air, so ping to the router is often lower and bandwidth is higher.
38 minutes ago, WestTexan said:
lol,made me chuckle
Use wireless if you don't need the very low latency, if you don't play multiplayer games where high pings matter.
You can use powerline networking if you don't want wireless (or the router is in a location from where wireless signals are hard to reach your location). You place one device by the router (could be the power outlet where the router's power supply is plugged into) and that device creates a network, it's like a network switch, to which the other powerline devices connect ... so you can plug a powerline device in your room and get ethernet and optionally wireless (if you get a powerline device that also has a wireless access point)
Powerline works best if the outlets are on the same circuit (same fuse in the electrical panel), works a bit less well if there's things like microwave ovens, washing machines, stuff with motors plugged in the same circuit with them... They can get you higher download speeds than wireless, and maybe more consistent high download / transfer speeds but they still have issues with latency, probably worse than wireless sometimes.
Ethernet is king.
Ideally, you would DRILL a hole in the corner of your room, maybe on that black bad at the bottom or right above that band and route the network cable along the wall.
Another option is to buy FLAT black ethernet cable and use some double sided adhesive tape to more or less glue the cable along the base of the wall, or use clips like the ones in the picture below to attach it to the wall
You may have to cut or sand / polish a bit of the wood on the door so that when you fully close the door, it won't compress / cut the ethernet cable if you resort to this
Here's an example https://www.amazon.com/Ethernet-Internet-Snagless-Connectors-Router-Black/dp/B06XXH72SZ/
You could go full fiber but you'll spend an arm and a leg on the equipment.
Other than that you have two options:
- either use an ethernet cable as was previously mentioned and run it along the wall (or maybe even through the wall if thats a possiblity?)
- use a WiFi stick on your computer to recieve the signal from your router.
I wouldn't suggest using a powerline adapter. I dunno how your powerlines in the house are routed and how they're shielded, but more often than not you will lose about 20-30% of the speed through the powerline and also will lose in reliabilty. Powerdraws will give you a certrain amount of packetloss - or even cap the entire connection for seconds. Definitly less reliable and slower than a good wifi setup.
USB adapters suck. If your going to do WiFi you do it right with a PCIe card.
Secondly WiFi is not as reliable as Ethernet. Just because it works for you doesn't mean it works for everyone. There are areas in the world where they build structures out of Concrete. Concrete and WIFI dont mix. WiFi also has higher latency than Ethernet. So in some games that can be an issue.
Very good generic info.  Wifi would be fine for him,  if you looked at the pic he posted.
USB adapters are more than fine for most people.  I know we're on a Tech Forum so that everything has to split hairs and be noted that it's 0.5% better or whatever.
Latency gets adjusted by the online game, so having good ping can be adjusted to where the wifi folks are.  Need to mention that too.  Don't just spout that wired is always better, cuz it isn't.
OnePlus:
Other Tech:
Its not about better. Its about reliability USB adapters are known to over heat and die quickly. Especially if your shooting shit loads of data thru them. You don't know how many posts I have seen people crying about their USB adapters stopped working. The best solution is to NOT buy one.
But it is. Its more reliable. Consistent and Faster. You're not going to get Gigabit speeds on WiFi but can easily achieve this or faster on Ethernet.
The easiest solution isn't always the best solution. But seeing as this is a tech forum, it also serves to educate the uninformed and offer the best/ideal alternative. The OP's conditions will ultimately direct the solution.
Most people don't think about running a cable, but if the run isn't absolutely contraindicated, the connection will be consistently more reliable (with lower latency) and faster than WiFi. WiFi can be faster, but the key is consistency, since WiFi is subject to interference.
Really? I can't say that I agree with this, unless I'm misinterpreting what you're saying.
High latency can be caused at any point between the PC's LAN and whatever server it's connecting to on the WAN. Most of the WAN is wired so, ideally, latency should be low on that side. A WLAN can introduce more latency before it even reaches there.
Not all online games will suffer from high latency, but those that require quick reaction will.
Yes they CAN treat everyone like they have the same latency, artificially limiting people with good latency to the same performance as those with poor.  But I don't think this is universally done and you're also missing the big issue with WiFi which is jitter, how the latency can vary considerably between one packet and the next based on what your neighbours WiFi is doing and the variability of radio communication in general.  Just someone walking around the house, putting the microwave on, even weather changes can impact WiFi.
Wired IS ALWAYS better as jitter should be around 0.1ms at worst rather than several milliseconds on WiFi, as you are not subject to changing conditions over the radio frequencies!  Plus the base latency will be something like 0.3ms whereas WiFi will always be at best three or four times higher than that.
Example, my laptop WiFi 6 vs Wired to my NAS:
PING server.lan (192.168.1.253) 56(84) bytes of data.
64 bytes from Server.lan (192.168.1.253): icmp_seq=1 ttl=64 time=3.81 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=2 ttl=64 time=4.24 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=3 ttl=64 time=4.07 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=4 ttl=64 time=4.02 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=5 ttl=64 time=3.69 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=6 ttl=64 time=3.92 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=7 ttl=64 time=3.94 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=8 ttl=64 time=4.23 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=9 ttl=64 time=3.88 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=10 ttl=64 time=4.67 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=11 ttl=64 time=4.15 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=12 ttl=64 time=3.78 ms
^C
--- server.lan ping statistics ---
12 packets transmitted, 12 received, 0% packet loss, time 11018ms
rtt min/avg/max/mdev = 3.693/4.033/4.673/0.255 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=1 ttl=64 time=0.174 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=2 ttl=64 time=0.150 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=3 ttl=64 time=0.143 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=4 ttl=64 time=0.140 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=5 ttl=64 time=0.125 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=6 ttl=64 time=0.181 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=7 ttl=64 time=0.145 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=8 ttl=64 time=0.146 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=9 ttl=64 time=0.128 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=10 ttl=64 time=0.125 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=11 ttl=64 time=0.125 ms
64 bytes from Server.lan (192.168.1.253): icmp_seq=12 ttl=64 time=0.143 ms
12 packets transmitted, 12 received, 0% packet loss, time 11016ms
rtt min/avg/max/mdev = 0.125/0.143/0.181/0.017 ms
Bear in mind this is WiFi in ideal conditions, no big variation in performance just to interference and only a a few feet from the Access Point with no other clients actively using it.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
