CPU overheating issue
3 hours ago, Tegneren said:From what I can see your case looks cool, but has bad airflow. Both the front main intake and the top exhaust is almost completely blocked off.
So that would be the culprit.
The GPU you have dumps basically all its heat into the case, and relies on the case airflow to exhaust it.
I would try removing the front and top case panels and see how the temps behave
1 hour ago, jaslion said:Not a surprise that case barelt has any front air intake. Better fans wont fix the issue if there is just no way to get air in easily.
Rip the front panel off or remove the side panel. Good chance any heating issues are immediatly gone.
Oh yes, I didn't look at the case, it's awful, absolutely disastrous with a 7900XTX reactor inside !!
@Rothinsky my advice is to change the case, and get a good airflow one instead (even a $60ish Deepcool CC560 is leagues better)
