Help with flutter
Go to solution Solved by RTX 3090,
Found a solution. Go to Finder, open the app manually. It will say unsigned, but proceed to open it. You can then close it, and it will be added to the security exceptions. From this point on the build will work fine
Hi, I am starting to learn flutter & supabase to develop apps. I have an issue where my code doesn't run on IOS simulator, and the Android simulator is greyed out. I have tried reinstalling the flutter and dart plugins, but still getting the same error. Any help would be greatly appreciated
Please tag me @RTX 3090 so I can see your reply
https://linustechtips.com/topic/1568190-help-with-flutter/
https://linustechtips.com/topic/1568190-help-with-flutter/#findComment-16391889
