Small / Desk Air Conditionner
By
NaniSalmon
in Cooling
in Cooling
Solved by Bitter,
They're either trumped up swamp coolers which only work in dry air and push humidity into the room and increases the apparent temperature (humidity makes it feel hotter than it is) or they're a peltier which gets hot on one side and cold on the other and so actually make the room hotter overall. What you need is a regular window unit or unit that ducts hot air out a window vent tube.
kisserik93 ·
Posted in Peripherals4 -
Rick13 ·
Posted in CPUs, Motherboards, and Memory11 -
6
popularlion ·
Posted in Troubleshooting5 -
2
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1
