How to reduce rgb brightness
John...
How do I reduce my led strip brightness? It's really bright, my fan hub doesn't have brightness optionScreenshot_2021-05-03-02-59-13-24.jpg.afb086727183be3150cc365c663570fa.jpg
If there is no method of control from the hub then you would have to put a resistor in line with either the ground or power line to the LED's to limit the current that they receive.
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
You can try using potentiometer if you like to tinker with stuff
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
potentiometer is a variable resister
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
What kind of resistor should I use?
What led strip is it?
The generic one, +12v, or addressable 5v?
Addressable 5v
27 minutes ago, John... said:
Addressable 5v
Well that's a little bit problematic...
Since is not only the led that needs power, each of those led has a chip on them that makes it address able, and let's just say the same thing happens when you suffocates people...
But i guess instead of cutting you led strip cable, you can buy cheap 5v rgb led extension cable and 10k potentiometer
https://www.amazon.com/MICRO-CONNECTORS-3-Pin-Addressable-Extension/dp/B07YYZ5WG6/ref=mp_s_a_1_10?
7 hours ago, John... said:
Addressable 5v
Ah I didn't not realize these were addressable LEDs. Ya you can't use a resistor in this case. The only way you can control brightness on those is through software. Since you don't have that option you either have to live with it or find new strips.
