Is there any reason why I shouldn't use plastic a water bottle as a reservoir for water cooling PC?
3 minutes ago, Toxibroke Gaming said:As far as I know we use it to easily refill or clean the cooling loop and add more coolant if needed and make it easier to set up.
I have a spare high pressure full plastic soda carbonation bottle at home so I hope to use that for filling distilled water.
As long as you are able to put the appropriate fitting holes and seal them up well, it should be fine. The only hesitation I'd have is that the fluid/air in the loop can become pressurized as it shifts between cold and hot temperatures, so these silicone sealers may pop out from the pressure or warp from the cold/hot shifting. I'm not sure if these would actually be considered issues, but those are the only concerns I have.
Also check out this article where the author uses a plastic bottle:
Water-cooling Reservoir Theory and Construction Guide - Overclockers
Hope this helps in any way
