New ASUS Oled monitor does not look like OLED...
SaddamAWP01
I just purchased new Asus OLED monitor 32 inch 240hz 4k, and it does not look like OLED it looks more like IPS panel, should I return it and get something better?
If you don't like the product and you have the right to return it for that reason, then go ahead.
Return window they said it was 14 days, and now I have 20 days with it already. But I don't like it, looks exactly like IPS panel.
Well, you're out of luck then. Shoulda made your choice during the alotted "make your choice" time.
Normal and legally there should be 30 days for return the item on online shopping, I reported them to Revolut, because they advertise it as OLED and is QD-OLED. And they have selection filters for OLED and QD-OLED. I will win the return anyway.
Oled does not look identical to ips. That is just not possible as ips has massive glow on dark sections.
QD-OLED's generally better than OLED so the error would be in your favor...
F@H
GPD Win 2
How exactly does it not look like oled. Are the colors wrong? Are dark areas grey like with IPS?
PC Specifications: Intel i9-14900KF, 5.8GHz all core locked, 5GHz ring, 1.35v High LLC, E-cores and HT disabled | MSI RTX 4090 Gaming X Trio | Arctic Liquid Freezer II 360 + Thermal Grizzly contact frame | 2x16 G.Skill Trident Z5 7400MHz 34-44-44-34 1T 1.45v (Tuned Subtimings, Hynix A-Die) | Gigabyte Z790 AORUS Elite AX | Windows 10/11 EVGA SuperNOVA 1000 T2 Phanteks P400A (Black non-rgb version, Phanteks T30 fans 3 intake (On AIO), 1 exhaust) | SK Hynix Platinum P41 2TB PCIE 4.0 (Boot drive), Samsung 870 EVO 2TB SATA
Displays: MSI MAG 271QPX 1440p 360Hz 27" QD-OLED | LG UltraGear 27GP950-B, 4K 144Hz (@120hz) 27" IPS
Desktop Audio: STAX SR-007 MK2 Electrostatic Headphones | STAX SRM-400S Amp | Schiit Bifrost 2/64 (NOS mode, USB in, XLR out)
Mobile Audio: Sennheiser IE 900 IEMs w/ 4.4mm cable | FiiO KA13 "Desktop mode" Disabled
Peripherals: Razer Huntsman V2 Full size wired with linear optical switch | Logitech G502 Hero
Yes, where should be black it should be light turned off actually, and is black-grey with backlight, let me upload a photo
That's probably due to wrong settings. On Nvidia when you go to the resolution page in the nv control panel it should look like this:
Black looks fine on my OLED with this. AMD probably has equivalent settings somewhere if you have an AMD card.
I have nvidia 4090 i check now
Also bear in mind OLED in a bright room with a glass screen will look grey, its reflection of the room lighting.  This is why some people prefer a matte screen and happens with any screen type.  I do believe WOLED (LG panels) has a slightly better reflection blocking ability, but the latest QD-OLED are supposed to be better than the older models.
Try to reduce light behind you and you will find it looks better.  Using it in a complete dark room should look dramatically different to an IPS.
There also may be different display modes that have different gamma curves, it could be in a bad mode as a high gamma will also wash out blacks.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
I have OLED TV near me and where image is black the screen looks like its turned off.
I have an LG C1 and while yes it does look darker than the photo above (as does my IPS monitor), the contrast of images on the screen in HDR looks quite flat compared to in a dark room.
It depends on the lighting in the room.  I keep my window blocked as it looks terrible if sunlight if shining into the room.  QD-OLED is also known to not cope as well as WOLED when it comes to light reflections, but the colours look better than WOLED in a darker room.
As mentioned very likely a settings problem. If the display isn't told to display full black it won't do so.
F@H
GPD Win 2
and how can I make it to display full black?
Maybe there's an option something like "black stabilizer", not sure if Asus has it.  Maybe "shadow boost".
If it's at very high then that might be the issue.
I edit my posts more often than not
Talks about the screen coating issue between QD-OLED and WOLED.
2 hours ago, SaddamAWP01 said:
at the very least the room is too bright, I can see reflections i both the pictures.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
QD-OLED has raised blacks when there is a lot of light hitting the front of the display. Other than that maybe you didn't set the correc RGB range in your GPU driver's color settings. Make sure it's set to 'full' (0-255) not 'limited' (16-235).
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
I've got the PG27AQDM and it's nothing like IPS, the contrast ratio is insane. HDR isn't designed to be viewed in a bright room, either. The screen coating is probably what's skewing your opinion. That's the only thing that would give your post credibility but it's too vague for anyone to comment otherwise.
Even in a full dark room, the black does not look like true oled black, there is a backlight behind that black.
Then you're looking at a software problem. You probably messed something up in the color settings, like I mentioned in my previous post.
But there physically isn't. I haven't seen a single person make the assertion you are comparing it to an IPS panel. The reality is, if both were side by side they would not look the same. The only thing that makes sense here is the panel coating is skewing your opinion, as it's always been a topic of controversy. But all variations of Samsung G3 QD-OLED use the same type of anti-reflective coating.
