LOW FPS ON A GOOD PC
Emir919
Hello guys I wonder why i have such low fps on csgo it's almost below 120 in competitive and between 70-90in deathmatch.
I5 10400f
Gtx 1080
16gb(2×8)ram
Btw i have tried almost all the things like going to nvidia control panel and change the settings set power to maximum performance reinstall the game reinstall windows  I have the latest update on my drivers all my settings are low my fps is not capped or anything.Idk where is the problem?
Please someone help me out!
Thanks in advance
Edit: I uninstalled the drivers using ddu still no changes
What resolution do you play at?
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
1080p ofc
yeah if your playing at 4k and ultra settings, it might be that
also check your drivers, bios, and see if there is bloatware slowing down your pc
also minimize any apps in the background if there are any
Don’t take everything I say seriously
take it with a grain of s a l t
1 minute ago, Emir919 said:
1080p ofc
That's definitely not normal then. I'd suggest you DDU and clean reinstall Nvidia drivers.
Main PC:
Peripherals/Other:
I mean i tested it also in fortnite and i get like 115 avg on epic settings
Thanks man I'll try it
that sounds pretty normal considering your specs.
What speed is your RAM and is it in the correct slots? (2nd and 4th from CPU usually)
Are you sure?
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
He said it's pretty normal for fortnite not csgo
1 hour ago, IkeaGnome said:
re you sure?
I think he meant that FN perf.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
Are you sure?
It's on 2666mhz and yes it is in the correct slots running in dual channel
I missed that part. @Emir919 what are your usages like? Are any of them at 100%?
That still looks a little low. You could always use DDU and do a fresh install of drivers.
Project Hot Box
Oppbevaring
I'll try tomorrow to unistall driver using ddu and I will also change the gpu thermal paste for lower temps also I will tell you about my usages
How high are the temps?
Project Hot Box
Oppbevaring
-> Moved to PC Gaming
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
