will pci express(1.0 obv ) will bottleneck for rx 470??
Cale
so imma buy rx 470 which is pcie 3.0... but mah darn dell motherboard got "pci-express"(that's what cpu-z says,so i guess it means pcie 1.1)... im saying does gpu uses pci slots 100%..? and if yes then how much it gonna bottleneck mah gpu??
  mah cpu: core i5-3340
8GB 1333mhz RAM
 350W psu(ill upgrade psu so dun worry )....
 it its bout 3%-5% performance drop then im okay with it.. .. please reply..
I very much assume it'd be PCIe 3.0 considering that's what the CPU runs.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
i would assume it's not showing a generation, because nothing is plugged into the slot, and it's not negotiating a generation as a result?
The motherboard and the operating system will switch pci-e slots from pci-e 3.0 to 2.0 or 1.1 if there's nothing installed on them, or if the device (video card, network card, whatever) isn't doing a lot of work, in order to save power.
Video cards can also switch between using 16 pci-e lanes to using only 8 pci-e lanes, if there's no need to use 16... again, in order to save power.
But yes, even if your slots are actually only 1.1, the video card should still work... it will just be less available transfer speed. pci-e 1.1 is 250 MB/s on each lane, pci-e 2.0 is 500 MB/s  and pci-e 3.0 is around 985 MB/s on each lane.
So with 16 pci-e lanes, pci-e x16 v1.1 is around 4 GB/s  which is equivalent of pci-e x8 v2.0 ,  which is almost the same as pci-e x4 v3.0
-> Moved to Graphics Cards
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
  • 1 month later...
On 2/24/2021 at 8:04 PM, LogicalDrm said:
first off im sorey for super late reply... and thank u guys so much.. its actually ivy bridges Processor and LGA 1155 socket...  both use upto pcie 3.0 ×16... finally figured it out.. it sucks to be a gamer but empty on pocckets llol
