Confusing CPU names: Why is Ryzen 5 better than 7
Solved by SupaKomputa,
CPU numbering is only related to the same generation.
Is to put a classification on the target performance / price.
3 for super cheap 2-4 cores
5 for i want performance but not to expensive ,5 to 6 cores.
7 for moar cores tha better,8 cores
9 for ultra fancy ,12 - 16 cores.
Now you must be confuse how a Ryzen 5 5600x be better than a Ryzen 7 3700x.
Because it is much better if you calculate the raw performance.
1 cores of the 5600x is around 1.3x single core of the 3700x so if you sum it up it would perform on par or better.
Back to the classifications it is still considered Ryzen 5 not Ryzen 7 because of the amount of cores it has.
