how make mic sound garbage
iamlegs
anyone know how to make a mic sound horrible? just want it so i can meme
Go to the dollar store and buy the cheapest earphones with a mic. Plug it in and find some program to max the volume input and scream into it :)
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
wrap a plastic bag around it, or put it in a bottle/somewhere enclosed with horrible echo
put it directly in front of your mouth without pop filter '-'
but i urge you not to do this in voice chat, only for recordings and videos
because this
-sigh- feeling like I'm being too negative lately
i dont think you know what i mean i want my mic to sound horrible not buy a new one
System Specs
Peripherals
<Razer Mini>
Turn it to 100% and yell into it from like 2 inches away
it works nearly 100% of the time, tested in a discord voice call
Current System: Ryzen 7 3700X, Noctua NH L12 Ghost S1 Edition, 32GB DDR4 @ 3200MHz, MAG B550i Gaming Edge, 1TB WD SN550 NVME, SF750, RTX 3080 Founders Edition, Louqe Ghost S1
Buy a cheap shitty mic from the dollar store and plug it into your front panel audio
Put it in your mouth then try to talk. They get alllll confused. Wouldn't do that with a large mic. Just a headset one.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
Use a bitcrusher??
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
