Posted October 22, 2020 https://www.cnn.com/2020/06/30/cnn-underscored/how-to-build-a-gaming-pc/index.html just BRUH Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 22, 2020 Verge is shaking. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 22, 2020 It's not really bad. The main article is explaining what parts you need for a PC, shows a couple of configurations at different price points, and recommends you search for build guides on youtube. There's nothing that I have found yet that is out right wrong. Maybe the configs they have given can be update/improved on but that's about it. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 22, 2020 5 minutes ago, theo.r said: https://www.cnn.com/2020/06/30/cnn-underscored/how-to-build-a-gaming-pc/index.html just BRUH Why is it bad? Post your comments and opinions. "Do what makes the experience better" - in regards to PCs and Life itself. Onyx : AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502 7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU - Cooler Master MasterBox Q300L - Samsung 27" 1080p Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p Steam Deck 512GB OLED OnePlus: OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green OnePlus Buds Pro 2 - Eternal Green Other Tech: - 2021 Volvo S60 Recharge T8 Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified. - Lenovo 720S Touch 15.6" - i7 7700HQ, 16GB RAM 2400MHz, 512GB NVMe SSD, 1050Ti, 4K touchscreen - MSI GF62 15.6" - i7 7700HQ, 16GB RAM 2400 MHz, 256GB NVMe SSD + 1TB 7200rpm HDD, 1050Ti - Ubiquiti Amplifi HD mesh wifi Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 22, 2020 Author Ok 1 $250 on the motherboard 2 $90 on the cpu 3 NO GPU 4 who needs an aio that is more expensive than the cpu 5 just get a case for a lot cheaper Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 22, 2020 A $350 case with a 3200g? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 22, 2020 This is a bit dissonant(?), as reading pure bs would be a waste of time. But how to know it's pure bs when haven't read it It's dated - July 1st of 2020 so the hardware mentioned is dated anyway.. I edit my posts more often than not Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 22, 2020 The build #1 is just atrocious, but other than that, they have the basis right. If you need help with your forum account, please use the Forum Support form ! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 22, 2020 The first one is...??? I'm more confused than anything. They/Them rgb go woosh woosh fps higher Ryzen 5 3600X | Asus ROG Strix B550-E | Zotac Gaming GeForce RTX 3070 Twin Edge | 32G DDR4 Corsair Vengeance RGB Pro | Corsair RM750x | Corsair 4000D Airflow Ducky One 2 Mini Cherry MX Red | Ducky Mecha Mini | Glorious Model D- Nintendo Switch | Xbox One Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 22, 2020 Better than the Verge did, so already fairly usable. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 22, 2020 Author I am checking out the verges pc build is this it https://www.theverge.com/2018/9/13/17828092/gaming-pc-build-custom-how-to-asus-intel-geforce-cost It is actually not that bad cnns one is absolute s*&^ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 22, 2020 2 minutes ago, theo.r said: It is actually not that bad cnns one is absolute s*&^ This is good? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 22, 2020 12 minutes ago, theo.r said: It is actually not that bad cnns one is absolute s*&^ how is this good ; Spoiler Cable management is horrible for the case they used, RAM isn't installed properly, it's missing a screw on the CPU cooler ... and then there's the video and the journalist and editor's reaction to the critics. Can you point out what's shit with the CNN article apart from the 1st build poor choice of parts? If you need help with your forum account, please use the Forum Support form ! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 22, 2020 5 minutes ago, nox_ said: This is good? This.Is.Sparta! Sorry, not good, but very funny. NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted October 22, 2020 In objectively, yes, and I could say.. Holy shit for these ridiculous builds. But somehow, in their perspective, it's just some writer, that trying to get paid. Welp, afaik, so correct me if I wrong, in their job, at least they have to write. Sometimes even no matter how shitty the writing quality is. Just. Write and post. Clickbait titles, we came and even we stayed for a second, rumbling 'tf is this', the site would gain revenue still. Except if we're using ad-block, of course. I've seen a lot worse articles than those somehow, like one of those in my country that reports about how a freaking artist can't differentiate a ripe or unripe banana. News website nowadays are just freaking, unbelievably, annoying to read. Ads everywhere. And what I mostly hate. Like. Every single one of news site. Even the one I thought would be at least, credible one. Like, Wikia. THEY FREAKING PLAY A 720p VIDEO AUTOMATICALLY. SUCKING MY PRECIOUS F***IN DATA. And, yes. I don't have fiber/wifi/else like that. I use data tether every single time I online. So it's freaking annoying for me. Spoiler But, heck. Turns out the auto-play video problem solved since I'm actually using Vivaldi tho. Indeed their built-in blocker works way better than I expected. Humor me, as you should do. Daily drivers, below. Diccbudd PC Intel Xeon E3-1225 v2 || ASRock B75M Motherboard || MSI GeForce GTX 1650 Gaming X 4G || Hynix 2x8 GB DDR3 1600 MHz RAM || 480 GB Pioneer APS-SL3 SATA SSD // 1 TB Seagate 2.5" HDD || be quiet! System Power 9 500 W PSU || Cooler Master T20 CPU Cooler || Samsung S19D300 Monitor || Fantech X6 Knight Mouse || VortexSeries VX7 Pro Keyboard Samsung Galaxy A34 5G 8GB RAM, 256GB Internal Storage, 128GB SanDisk Extreme, and you could find the rest of the specs on the interwebz lol Lenovo ThinkPad L390 Yoga Intel Core i5-8365U || 8 + 16 GB DDR4 (don't ask, gf bought me the 16 GB RAM as my birthday present lol) || Samsung 256GB SSD Personal Server: CasaOS, Home Assistant, ESPHome, Jellyfin. AMD E-350 || 3GB DDR3 || 120GB random SSD || 1TB Toshiba HDD Audio Redmi TV Soundbar || KZ EDX Ultra + KZ APTX Bluetooth Module || JCALLY JM6 CX31933 DAC Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
