Deshrouded GPU optimal fan placement ?
2 hours ago, dead man jack said:What is the optimal fan placement i have a few sizes in thin fans to work with. 120*15 ,120*14 ,90*15 ,40*10 .
You can't fit 25mm wide (otherwise I'd just use 2 Arctic P12) ?
Two 120*15/14 like on your picture should do fine. I'd ditch the small 40 one.
Dust the heatsink first.
(I recommend Fan Control for controlling the fans.)
2 hours ago, dead man jack said:and I've always wonder what's the go with the center of the fan where the motor is , dose that block airflow should i line it up with gaps between the two coolers in a perfect world ?
You won't fine a placement with a gap only under the motor.
Edit : Oh ! you're not pushing air, you're exhausting air (or ?)...that might change things (gaps impede performance),
I'd make try outs. Try something, launch a stresstest, check temperature...keep the best one.
(On my cpu cooler, for instance, I even close a gap with cardboard)
