Afaik, the M is the one that comes with the mesh panel, it's a decent ATX case.
looks are subjective though.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1238183-cooler-master-h500m/#findComment-13953848
1 minute ago, vermeulenbertho said:
i was wondering if the Cooler Master H500M is a good case?
It's a decent case, I just think it's horribly overpriced and has a lot of plastic in its construction.
A case is just about holding the parts inside of it and not impeding airflow (too much), so it's very personal if you should go for this case or something else.
https://linustechtips.com/topic/1238183-cooler-master-h500m/#findComment-13953857
10 hours ago, vermeulenbertho said:
picked it because it looks similar to the nzxt cases and i like the simple design,
As i said, it's a decent case, if you like the looks then good.
Build Log:
https://linustechtips.com/topic/1238183-cooler-master-h500m/#findComment-13953860
The M is the "top of the line" version of the Mastercase H series, but it's features are mostly extra styled exterior panels, ARGB 200mm fans instaed of RGB, and an expanded front I/O.
All H series cases except the original H500P come with a mesh front.
Just now, vermeulenbertho said:
sorry i meant the Cooler Master Silencio S600 case
Well, that's definitely different.
It will keep your system quiet, but not cool. If you're running a gaming or workstation PC, it would likely not be suited to keeping your temperatures in check.
https://linustechtips.com/topic/1238183-cooler-master-h500m/#findComment-13953870
It will have the same problems the NZXT cases are cursed with, terrible airflow and thermals.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1238183-cooler-master-h500m/#findComment-13953891
