Searching for most effective air filter material
startrek03
Hello,
There are couple of air filter materials on the market. The most common from my understanding are those really fine meshes, that most case manufacturers use in their removable fan filters, the less fine filters, that are either used as permanent fan filters or are purchasable on the internet. And there are these foam ones. So, of the second type I know, that they filter out rough dust but not the fine stuff you will hardly get of the PCBs without maticulous cleaning.
I know that better filtering usually decreases airflow. However, I want a solution that allows me to clean my PC as rare as possible and my plan is to use overpressure and efficient fan filters to reduce the amount of dust in the case as much as possible. Cleaning the filters regularly is way easier than cleaning the whole PC. Obviously.
I'd really appreciate your advice and your suggestions. Thanks a lot in advance!
more filter creates less air flow obviously.
maybe you could try having negative pressure, get the filter on the air intake only.
any dust inside will be blown outside.
The problem with that is, that in almost any computercase are tiny holes, through which dust will enter. That basically defeats the purpose of the intake filters...
the mesh that is on most decent-quality cases these days gets you about 90% of the way there.
another thing to consider is, the more dust your filters stop, the more often you'll have to clean (or replace, depending on material) your filters.
i ran my computer with kitchen extraction hood filters for a while, pretty much zero dust.. BUT i had to replace the filter pretty much on a weekly basis...
That's positive pressure fam
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
If I had something, I can clean quite easily this wouldn't even be such an issue imo. Better than taking the whole computer apart once in a while and cleaning more difficult to clean stuff like PCBs and fans, heatsinks etc.
well, just filter everything, close the holes and the gap, let the exhaust fans do its job.
I prefer this approach then a positive pressure.
if you put 1 intake and 3 exhaust, that's negative.
minimal airflow = minimum dust
so maybe try passive cooling? i've done it on my old i5 6600 system, not sure if it's possible for yours
but yes, the finer the filter, the harder is it for airflow and dust to get through
so you'll really sacrifice on thermals
as for material, HEPA filters will pretty much block most visible dust particles
-sigh- feeling like I'm being too negative lately
I was thinking about HEPA filters at some point (I'm stupid I know), but right now I really want something reusable because of environmental reasons. Throwing such a filter away every month or so is really not worth it imo.
i doubt you'll have to change HEPA filters THAT often tbh
but i would think most filters that filter fine dust particles like these arent reusable, because the dust particles are too small to be washed/blown out
What you were describing when you said negative pressure above was positive pressure, when you have more air blown into the case than out of it, air escapes through cracks and crevices in the case.
Negative pressure, more air blown out than sucked in, causes air to be sucked in through said cracks and crevices and bring dust with it.
desktop
HTPC
That's probably true. But my common sense tells me that other filter types might be usable for way longer than hepa filters since they're not really cleanable at all afaik.
ive seen car mechanics re-use HEPA filters by just blowing pressurized air in the reverse direction
that probably gets rid of most dusts, but idk if i would recommend that
ever thought of getting a decent air filter for your room so there's less dust to begin with?
I never said to have more air blown inside.
Yes air will sip in small crevices, you can close them off if you want to.
I neither have AC nor venting. I pretty much rely on windows. And getting a window sized HEPA filter isn't really feasible, right? However, I plan on lifting the case a bit from the floor. That might already help a lot with dust.
To achieve the necessary seal on a common PC case you'd basically have to dump it into a silicone bath.
pretty sure there are house sized HEPA filter if you ask for it ahaha
but yea, lifting your case off the floor should improve your situation a lot
though my PC on my desk also gets dusty eventually
I'll probably try the foam ones at some point of time, since similar ones are used in dryers in combination with those fine mesh ones. If I find out something a year or so later and still remember, I might post something on the forums.
