Hey so my old pc that is 15 years old Is almost dead and i need it to die faster so i can get a new one. What are your suggestions to do it without traces and without buying any equipment like usb killers and such. My dad wants it to die also because my mom said she is only buying a new one when this one is unfixable
https://linustechtips.com/topic/1219670-help-me-kill-my-pc/
I don't exactly know how to feel about this...
CPU: Ryzen 5 5600x  | GPU: GTX 1070 FE | RAM: TridentZ 16GB 3200MHz | Motherboard: Gigabyte B450 Aorus M | PSU: EVGA 650 B3 | STORAGE: Boot drive: Crucial MX500 1TB, Secondary drive: WD Blue 1TB hdd | CASE: Phanteks P350x | OS: Windows 10 | Monitor: Main: ASUS VP249QGR 144Hz, Secondary: Dell E2014h 1600x900
https://linustechtips.com/topic/1219670-help-me-kill-my-pc/#findComment-13800975
I would recommend being a decent human and not destroying something that you *likely* didn't pay for, so you can get someone else to pay for a new one.
What has this world come to.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1219670-help-me-kill-my-pc/#findComment-13800986
I actually did pay for it myself but its showing age and is just horrible to work on after you turn it on the only thing that only lags is the dekstop just look at it for 2 hours
https://linustechtips.com/topic/1219670-help-me-kill-my-pc/#findComment-13800991
1 minute ago, Electronics Wizardy said:
turn off the fans and let it cook?
Wont it overheat and shut down? I took the cpu heatsink off it just turned of after 2 minutes. Is there a bios setting to prevent it from turning off. Btw i tryed to overclock it to stupid speeds so it would burn but its running at 4.8ghz idk how :D
https://linustechtips.com/topic/1219670-help-me-kill-my-pc/#findComment-13800998
can you crank the voltage? Send like 1.8v to the cpu, that should make it end pretty quickly.
https://linustechtips.com/topic/1219670-help-me-kill-my-pc/#findComment-13801006
Your obviously bent on doing this ... Easy break off a pin on the cpu.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1219670-help-me-kill-my-pc/#findComment-13801017
Then buy another one.
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1219670-help-me-kill-my-pc/#findComment-13801019
Maximum on this motherboard is 1.7 volts and it doesnt turn on after that but it isnt dead it shows Clear cmos on screen
https://linustechtips.com/topic/1219670-help-me-kill-my-pc/#findComment-13801032
I have a Q6600 build that boots faster than Haswell and Skylake builds I've used off of a $20 60gb filled with nothing but the lowest quality spare parts like a 430w TR2 psu and a random frameless gpu fan that I screwed to the southbridge to keep it under 80c. It refuses to die and is one of the snappier builds to use that I have kicking around.
Don't kill it, get a better C2Q or do a LGA771 Xeon mod on it. Get the cheapest gpu/display adapter you can find, clean it up nice and sell it with an SSD for $100-150. Old gpus are really what hold back performance as far as games and what not, you're not going to do anything crazy with it and I don't think those cpus support SSE for like EAC games but stick a $50-100 GTX 970 or similar performance gpu in it and you'll be really surprised what they can do.
As far as destroying it, why bother trying to short it out or brick it or whatever... Unless you make the PSU pop, it's just going to turn off and maybe make a quick spark and a very small puff of smoke. Go get a sledgehammer or something, at least that would be fun. Throw it off a cliff or down a hill, ect.
https://linustechtips.com/topic/1219670-help-me-kill-my-pc/#findComment-13801057
What I would do is work for it myself or teach the person who is buying you a new one that it is old and isn't on today's standards. You could always just remove a capacitor that is important or as other people said bend the CPU pins (I have more ways in mind learned them the hard way)
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
https://linustechtips.com/topic/1219670-help-me-kill-my-pc/#findComment-13801064
I could never xD
Reminder⚠️
https://linustechtips.com/topic/1219670-help-me-kill-my-pc/#findComment-13801072
Instead of bricking a perfectly good piece of hardware, why not just pull the CPU out and put the cooler back on? No permanent damage and it won't turn on.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1219670-help-me-kill-my-pc/#findComment-13801077
-= Locked =-
Ok I think this has run its course.
I personally would not destroy a good piece of equipment. (sans the suggestion I included)
You have received several ideas, thus I will lock this now before its starts to dive into less than desirable conversation.
I have removed comments dangerous in nature.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1219670-help-me-kill-my-pc/#findComment-13801109
Guest
