I moved my NAS into a bigger case recently. While moving it into position, I accidently bumped the USB flash drive in the back and damaged it, the drive was still working, but is bend at the connector end on the PCB. It was working fine after that for about 24 hours and then suddenly all the dockers stopped working. I tried to restart it, but it doesn't post anymore after that. Everything turns on and has power, but I'm only getting a blank screen. The LED is stuck on boot. I tried a new USB flash drive with the flash drive backup and using another port, but that's also not posting. Unfortunately I can't listen to the beeps, as I don't have a speaker to connect to it. I tried reseating the CPU and following this thread:
Components:
ASUS PRIME H610I-PLUS D4-CSM
Intel Core i3-12100 processor
Corsair DDR4 Vengeance LPX 2x8GB 3200
Cooler Master MWE Gold 550 Full Modular V2 PSU
Unraid 7.3.1
No GPU
Is there anything else I could do? Thanks for the help!
https://linustechtips.com/topic/1638864-unraid-nas-wont-post/
Probably more stupid than you
Ryzen 5 5600x | RTX 3060TI | 2.25TB
"Professional" IT Support Analyst
Unlikely to be online, but I do check sometimes!
I have an information processing disorder. If you need me to clarify some information, please let me know and I will endeavour to make it understandable.
https://linustechtips.com/topic/1638864-unraid-nas-wont-post/#findComment-16906778
