Hey! I am brand new to this RAID Stuff I just got my first server a Dell R730 and I used a few drives that I had laying around the drives that are currently in the server are
4 x 465.25 GB HDD
2 x 1862.50 GB HDD
And when I quickly setup this server I just setup a RAID 5 array and added all the drives into the array. But I am noticing that the total usable space on the array is not adding up and when I expand one of my 2TB drives it says: Used RAID Disk Space 465.25GB
And my main question was what is the best configuration to setup the drives and get as much USABLE storage as I can. But also have the peace of mind of expanding all my drives to like IRON WOLF drives later on and expanding some drives to like 12TB drives.
https://linustechtips.com/topic/1638868-need-some-help-with-raid/
RAID uses the smallest capacity drive as base, any extra capacity on larger drives is essentially wasted.
For your use case, do the following:
  • delete your current RAID
  • create a RAID0 with 4x 500GB drives (md0)
  • create RAID5 with md0 and 2x 2TB drives (md1)
This maximises your storage to 4TB and you have one drive redundancy.
"You don't need eyes to see, you need vision"
(Faithless, 'Reverence' from the 1996 Reverence album)
