Case that help holding videocard
SeeSound
Go to solution Solved by TVwazhere,
1 minute ago, SeeSound said:
Case that help holding videocard, saw somewhere video that new cases can help hold heavy videocards.
But cant find single one, which direction am i looking for.
Some cases come with GPU supports, but there are a lot of aftermarket solutions.
Cases that have native GPU anti sag features include the Mastercase MC500 (series) which comes with a GPU bracket sold as an option
http://us.coolermaster.com/product/Detail/case/masteraccessory/mport-graphics-card-holder.html
The two most common styles of aftermarket brackets are support bars that use PCI-E slots to mount and sit under your card, or a standalone adjustable tower that is positioned toward the end of your GPU.
https://www.amazon.com/gpu-support-bracket/s?k=gpu+support+bracket
Generally it isn't the case that does the work, it is an aftermarket bracket that just screws in with your GPU.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
i found one ,ASUS ROG Helios ATX Case
That case does have the vertical gpu supports, however, I wouldnt get that case just because it has those. That case has a lot of downfalls, frstly being it's overpriced, secondly it's not designed with airflow in mind, meaning gaming PC's will  get very warm in that case to the point of reducing speeds.
