Gigabyte mobo Front Connection question
Solved by DanteCoal,
19 minutes ago, Lurick said:It should work, found similar questions on Reddit:
You're a scholar, a gentleman, and a savior. That's the EXACT info I needed, and for some reason just couldn't find.
May all your temps be low, and your OCs be stable.
Hakamedaa ·
Posted in Troubleshooting0 -
1
3
2
DudeSquad11 ·
Posted in CPUs, Motherboards, and Memory10 -
DudeSquad11 ·
Posted in Peripherals5 -
1
4
