My First Ever PC
AshurC
Hey guys just wanted to show my value gaming PC, this being the first PC I personally bought/owned I am pretty proud of it (though i know its nothing special).Also wanted to show just how expensive computer parts are in Australia compared to North America.
Inside is:
-Intel i3-4130 $175
-Asrock H87 Fatal1ty $145
-Crucial DDR3 1600 8gb $99
-Samsung 840 evo SSD 120gb $139
-Sapphire Radeon R9 290 4gb $599
-Coolermaster 750W GX2 $129
-Tsunami SC-01 Case $39
-Deep Cool XFan 120mm x3 $30
-Total $1335 - $55 = $1280
Basically what I was going for to being with was just basic components for a low as possible price, with a without compromise GPU. I was also aiming for a certain degree of upgradability for when i get a little more money, without having to replace expensive components.
Side note, I'll be moving to a bigger case soon and hopefully running a custom water cooling loop because it get pretty damn hot here in Australia and the reference cooler on the 290 just isn't cutting it.
i3 with R9 290  :(
aye looks good but..
That mobo is so expensive, better off getting a more expensive CPU on a cheaper bord. It may bottleneck the 290.
Looks pretty good, do why you got a ref 290 for $600, I can get a non-ref 290 for 580 AUD.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
Im not too much of a fan with the case and i think you would have been fine with a 600w psu, instead of getting fans you could have got a better case. Just some feedback but overall its a pretty solid build, people seem to under estimate the ferocity of the i3. And btw dont push it, this is by no means a budget build. My build for example costs around £650-£700 and that took me around 3 years to amass.
Listen if you care.
build looks ok but damn, i3
get an i5 3570 cause that cpu will probably hold back the gpu
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
i3 with R9 290  :(
either that or an i5 with a r9 270x, think about that for a second, what would you get.
Listen if you care.
i5 with 270x. Atleast I would.
cpu bottlenecks will not matter if mantle goes well and as i said above getting an i5 would cause the gpu to go down in power dramatically.
Listen if you care.
Let me be the first to tell you a i3+ 290 will completely shit on a i5(4.5ghz)+ 270x period. i3s arent too powerful but its not a massive bottleneck.
Listen if you care.
But then later down the line 270x is easier to upgrade and i3 will fall off.
if you're a gamer that's the dumber choice.
Also a friend of mine has an i3 (1st GEN i3 530 with a stock speed of 2.9 GHz though it's overclocked to 3.5) and he runs anything my i5 runs just fine with my GPU in his rig. Most games aren't too CPU dependant and rely more on the GPU.
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
That cable management though :/ Maybe if you've got some free time on your hand then work on the cable management
i3 with R9 290  :(
I'll suss out some Benchmarks for stock speed R9 290's and see what I've been getting becauise so far it seems like it hasn't been affecting performance, also in the future i plan on throwing in an unlocked i5 and liquid cooling. But i didn't want to have to upgrade my gpu.
Well considering 700 euros is around 1100 AUD I didn't do that bad, and the 750W PSU was me getting ripped by the salesperson i guess, he kept assuring me I'd need at least a 750W for the 290
Exactly what i was thinking, upgrading to an i5 later is cheaper than upgrading the GPU.
and later down the line mantle and other apis will be more gpu dependant then cpus as a result bottlenecking will be a thing of the past, mantle may fail and that is possible but it has already inspired others and im sure nvidia are working on something similar and maybe microsoft.
Listen if you care.
Believe me that was me trying really hard aha, this case has little to no cable management options and i thought about throwing in some cable ties but i figured it didn't have a window so i would wait for the next case to do some tidy cable management
nothing wrong not having cable management if the case is closed. also cable management (here comes the hate on me again) is actually more prone to short things out than cables all over the place but not grouped up and folded all over.
D-Comp in Liverpool, I had a look on ebay and the non-reference cards were running around $610 versus $600 for reference plus I figured the blower style would be better for the smaller case (or so I've been led to believe from linus' video's). That is of course if this qualifies as a small case :S
Looks a bit overkill with the gpu there.
And how come all the parts are better than me except for the cpu? You should balance it a little.
K, if your happy with it than that's really all that matters :)
I figured I would upgrade the CPU when i had money to liquid cool, which would involve a new case and rads fans etc, so i got a cheap(ish) i3 while i save for all that.
Fair enough, if you're happy with it then it shouldn't be a huge issue
Cable management could also improve air flow though by quiet a bit, when I've build my pc and set it up I didn't bother at all with the cable management but when I was about to add the finishing touches (the magic touches) I chose to neaten up the cables and got around 5C less
i did make sure that non of the cable's were blocking the fans, i guess the pics didn't really show i but there's a fan at the front bottom and two in the side panel.
Still looks pretty swell though
