surround sound amp/dac advice please? Dolby Atmos? DTS? 7.1 Virtual?
Solved by The Flying Sloth,
I must stress though that the endorsements I found relate only to interfaces with dedicated headphone amplifiers so the cheapest option from Behringer will be the UMC202HD and the Cheapest from Focusrite the Scarlett 2i2, now, I'm sure there are probably other interfaces with the ability to power the headphones for less money but I just don't know what they are and without direct endorsement from the manufacturer or a trusted forum member (here or otherwise) I don't want to tell you to buy something that I think can power it (like the Swissonic UA-2x2, Presonus AudioBox iOne or Native Instruments Komplete Audio 1) and be wrong.
Sloth
