amp/dac advice please? Dolby Atmos? DTS? 7.1 Virtual?
Falenkor
Go to solution Solved by The Flying Sloth,
I must stress though that the endorsements I found relate only to interfaces with dedicated headphone amplifiers so the cheapest option from Behringer will be the UMC202HD and the Cheapest from Focusrite the Scarlett 2i2, now, I'm sure there are probably other interfaces with the ability to power the headphones for less money but I just don't know what they are and without direct endorsement from the manufacturer or a trusted forum member (here or otherwise) I don't want to tell you to buy something that I think can power it (like the Swissonic UA-2x2, Presonus AudioBox iOne or Native Instruments Komplete Audio 1) and be wrong.
Sloth
@Falenkor if you buy the c2 set you can drop the mic booster which means it'll be around the same price.
Quote me for a reply, React if I was helpful, informative, or funny
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
Still not seeing what you two are talking about here.. I see the set of microphones of the c2 for $70+ got a link for what you guys are talkin bout here?
@Falenkor I also see it for 70 but it still costs the same if you go with the dynamic+mic booster or a pair of c2 and no mic booster.
AMD blackout rig
8 minutes ago, Falenkor said:
nope, Not seeing this set under $40 got a link to one?
Yep, though I didn't notice the shipping cost which would bring the total for mic, interface and amp (including shipping) to $130.
Thomann is the world's largest online music retailer, located in Germany so German (and European) stuff (like behringer) is crazy cheap
They don't break, like I said, I own 4 and have treated them pretty rough, not a single problem.
Sloth
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
1 minute ago, The Flying Sloth said:
Yep, though I didn't notice the shipping cost which would bring the total for mic, interface and amp to $130.
Sloth
hmm, any way around those shipping costs?
Why wouldn't you get a mic booster though? Thought that would be needed
You need mic booster for dynamic mics but for condenser mic you need phantom power which is on your audio interface
AMD blackout rig
Booster is only for dynamic mics, wouldn't need it for the C2, that's what he's trying to say
Not that I've found but the shipping is a flat rate so if you ever wanted to grab a new guitar... Or anything really.... The Thomann brand stuff is crazy high quality for real cheap.
It's a smart move on their part, encourages people to buy bulk (and people like me fall for it constantly)
Oh, and before I forget, you would need a mic cable too, would suck to forget that.
Sloth
@rice guru
Sloth
well, a mic cable and a boom stand
Sloth
hmm I dont think a regular boom arm stand that attaches to a desk will work on such a small mic right?
I mean, I'm using one in the picture I linked....
@rice guru
