First Build in 4ish Years. What should I change?
I already have plenty of storage (Nvme SSD and sata SSD) and an RTX 2070 from previous laptops and my EGPU.
I want a beefy CPU because that's currently my main bottleneck and I'd like to be able to build projects quickly for my job (Software engineer)
PCPartPicker Part List
Type Item Price
CPU AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor $434.00 @ Amazon
CPU Cooler Cooler Master Hyper 212 Black Edition 42 CFM CPU Cooler $34.17 @ Amazon
GPU Aorus 2070 Free from E-GPU
Thermal Compound Arctic Silver 5 High-Density Polysynthetic Silver 3.5 g Thermal Paste $6.49 @ Amazon
Motherboard Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard $189.99 @ Best Buy
Storage 256 GB Intel NVME ssd + 1TB Samsung 860 EVO Free from previous machines
Memory Patriot Viper Steel 16 GB (2 x 8 GB) DDR4-4400 Memory $164.99 @ Newegg
Case NZXT H510 ATX Mid Tower Case $69.98 @ Amazon
Power Supply Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply $124.99 @ Best Buy
Keyboard ADATA XPG INFAREX K20 Wired Gaming Keyboard $44.99 @ Newegg
Prices include shipping, taxes, rebates, and discounts
Total $1,069.60
What do y'all think? Will the Hyper 212 be enough to cool the cpu with some light overclocking?
Am I overpaying for features I don't need?
Should I make any changes?
Thanks!
hyper 212 is just going to be a mild improvement over the stock cooler. For a cpu of that caliber, you probably want something much more beefy.
The memory is definitely overkill though.
Free from E-GPU woooooooah how r u getting and rtx 2070 free?
NOTE: I AM NEVER ALWAYS RIGHT, BUT I AM HAPPY TO HELP ANYWAY I CAN
Tag me @WambleCropped or quote me so I can see your reply
My Rig: RTX 2060, R7 1700X, Samsung 860 500GB, Masterlite Liquid Cooler, Asrock Pro B540,16GB of RAM G.Skill 2133
PSU Tier List                    SSD Tier List                              Graphics Tier List
Any cooler you'd recommend?
What about the memory is overkill? I was under the impression that clock speed really mattered for the new AMD CPUs
Don't cheap out on the cooler. Hyper 212 is ok but like @Saksham said, it's barely an improvement over stock.
Maybe get something like a noctua nh-u12s Chromax instead if you just want a "small" heatsink or the NH-D15 Chromax for a beefy cooler that's on par if not better than most AIO.
Also while RAM is overkill, it's technically supported by both CPU and motherboard... Sooooo Yeah. It should work. While Ryzen does benefit from faster RAM, there's still diminishing return past a certain point.
CPU: AMD Ryzen 3700x / GPU: Asus Radeon RX 6750XT OC 12GB / RAM: Corsair Vengeance LPX 2x8GB DDR4-3200
MOBO: MSI B450m Gaming Plus / NVME: Corsair MP510 240GB / Case: TT Core v21 / PSU: Seasonic 750W / OS: Win 10 Pro
personally I love my masterlite AIO cooler pretty cheap and good price to performance
I'd recommend the BeQuiet! Dark Rock Pro 4 or Noctua NH-D15 Chromax.
4400 MHz is above the point of diminishing returns. The sweet spot for Ryzen is 3600 MHz
F@H    EOC
Well it's not free. It's free as in I'm not budgeting it's cost into this build
You could go for an NH-U12S (or U14S) if you want air or a Corsair H100i Pro if you want water
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
I would get the Patriot Viper Steel 16 GB (2 x 8 GB) at 3733Mhz or 4000Mhz max, and then use the $60 or so dollars you save to purchase a Noctua NH-D15 CHROMAX Black (or the non-CHROMAX Black version if you don't mind the brown/white color scheme). The NH-D15 will trade punches with most AIOs in terms of cooling performance and will be equally quiet or quieter while having the added benefit of being very low maintenance.
