Looking for a 144hz monitor for around 250$
Cpt. William
I am looking for an upgrade to my old monitor. I will be playing games like counter strike and rainbow six siege and watch youtube videos. I am loking for a monitor around 250 USD$
If you have any suggestions, let me know ?
You can actually use PCPartpicker to shop for monitors too!
Here's a 1080P 144hz filter for monitors under $250
https://pcpartpicker.com/products/monitor/#r=192001080&D=144000,240000&X=0,25804
The Asus VG248QE is a tried and true standby, thats a bit old these days but still gets the job done
https://pcpartpicker.com/product/rkphP6/asus-monitor-vg248qe
You can also get versions with IPS panels which have better color reproduction and Free Sync technology built in
https://pcpartpicker.com/product/C8QfrH/acer-vg240y-pbiip-238-1920x1080-144-hz-monitor-umqv0aap01
https://pcpartpicker.com/product/vhQG3C/asus-vg279q-270-1920x1080-144-hz-monitor-vg279q
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
Around that price point, there are some compelling options but the #1 problem you will run in to is ghosting artifacts. I currently am using a monitor from around that price point, the MSI Optix MAG241C (144hz 1080p curved monitor, about 23in) and yes, it does indeed do 144hz and FreeSync, but in quite a few games such as GTA, I notice significant ghosting. In GTA, I notice it as a yellow smudge behind an object that is moving.
Here's a link if you want to see it
**EDIT**
This monitor also works with G-Sync, although it is not technically on nvidia's recommended list. Most programs run fine in full screen or borderless windowed, but there are some GPU accelerated programs, like Paint.net and Handbrake (video encoding/transcoding) that cause stuttering and flickering.
It is not g sync certified. But is gsync compatible.
Quote me or mention me at @Shrekpad so I get notified
pc specs:
CPU:
Intel i7 8700K MOBO: ROG Strix Z390-E Gaming RAM: 16GB (2x8) DDR4 G Skill TridentZ 3000 MHz GPU: Gigabyte GeForce RTX 2080 SUPER GAMING OC CASE: Phanteks Enthoo Evolv STORAGE: Sabrent Rocket Q 1TB M.2 NVME SSD,
T-Force Delta RGB 250GB SSD, 4TB Seagate Barracuda HDD PSU: 750 Watt EVGA SuperNova G3 MONITERDell S2716DGR 1440p 144hz G-Sync, BenQ PD2700U 4K 60hz CPU COOLER: Corsair H115i RGB Platinum OS: Windows 10
