XFX RX 5700 XT Thicc III FPS issue
chuckM
Using a 50 inch vizio 4k tv and it seems like all my games get only 30 fps max and I get major stutter. Cinebench15 says I get near 200 fps. I'm confused and feel like I just wasted 0ver $400 on a bad video card. Am I missing something? Previously had an RX 590 Red Devil and I never had this issue.
P3 Case
Asus TUF x570 Plus Wifi
16gb DDR4 4000 running at 4266
R5 3600x with a Thermaltake AIO
256gb NVME SSD with a 1TB HDD that I run all my games off
850 watt evga psu
RX 5700 XT
9 minutes ago, chuckM said:
Even something like CS:GO runs poorly?
Does it score normally in firestrike as well?
Did you already try reinstalling windows? It's usually the quickest solution for software issues.
a new driver just came out as well.
CSGO is giving me 250 FPS but i go through walls and floors and cant walk no place
I ran firestrike and i'm getting a max of 65 FPS
I'm running Driver 19.12.2
Diablo 3 gives me only 30 FPS
2 minutes ago, SnowWolf370 said:
I know some TV's have a problem with really high FPS, since nothing a TV usually displays is a high FPS. Video games, movies, TV series are all usually down in the 24's.. Maybe 30.
I had an old Hanspree 37" LCD TV that took suicide whenever it got a 60 FPS image, lol.
Do you have a regular computer monitor you can give it a go on?
I only have the 50 inch 4k
Wait what?
Probably just throw a fresh copy of windows on it if you haven't already
Can also make an ubuntu USB, and run Steam under Linux to see if it's a windows issue.
The TV shouldn't have any effect on your fps.
Do you have V-sync enabled? Or other fps limiters?
Previously had the RX 590 - did you DDU and reinstall all drivers?
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
Yes like 4 times, had so many issues just getting the driver to install right
Are you trying to run those games at like crazy high settings or something? I've no idea why there would only be issues in some games.
Seems like no matter what settings I do its low frames especially Diablo 3 and tom clancy the division 2. CSGO gets good frames. cinebench gets like 198 to 210 fps but seems to get lower every time i run  it
I guess your GPU could just be overheating a ton or something when it's put under a heavier load
probably just return/exchange the card if linux doesn't fix it either. Maybe try a different model
Are you on the latest motherboard bios?
Did you even have a look what’s your temps?
   @Whiro tag or quote will do the trick
i5 3570K @ 4.7Ghz  |  AsRock Fatal1ty Z77 Performance  |  Corsair Vengeance 16GB 1600MHz  |  ASUS Strix GTX 970 OC  |  Phanteks P400S TG  (mesh panel) |  EVGA 500W1  |  Storage: Corsair 60GB SSD (boot), Gigabyte 120GB SSD, WD 2Tb HDD | Cooling: Custom loop
                EKWB EK-XRES 140 Revo D5 RGB PWM
                EKWB EK Supremacy Evo , naked die
                EKWB EK Thermosphere
                EKWB EK CoolStream PE 360
                EKWB EK Coolstream SE 120
                EKWB EK Vardar 120s  x6
                EKWB EK STC Classic 10/16  x10
                EKWB EK DuraClear Tubing 16/10
                EKWB EK CryoFuel Acid Green
Laptop: Gigabyte G5-KC | i5 10500H | RTX 3060
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
This screams out at me too... can you clarify what this actually means to you?
It should install drivers fine on a well balanced cared for system... (if the GPU is also nonfaulty)
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
  • 3 weeks later...
I returned the RX 5700 XT back to XFX . After much trial and error the issues could not be resolved. Screen going black during gaming and sometimes crashing the computer. I went ahead and replaced it with an RTX 2060 Super. I have had no issues and my computer is smooth as butter. You know , now that I think of it the RX card jacked my cpu temps to running at 50° c. Now my computer is running at 28° c.
5700 cards and drivers are known to have massive issues.
I kinda feel it's too late in the cycle for that ever to change.
This also will further contribute to the fact many people prefer NV simply because of reliability and usability...
AMD always has some kind of "Nvidia killer" out but it never materializes in real world performance.  Not everyone is Gamernexus who can probably overclock tomatoes to run circles around Nvidia  ?
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
XFX 5700 (non XT) and after installing latest AMD drivers and utilizing the individual game settings (Not Adrenaline), zero issues with Diablo 3, Star Trek BC VR, Dr. Who VR, Witcher 3, World of Warships, The Division 2, Assassins Creed Unity, WoW, Elite Dangerous and Superhot VR. Now, I'm still having weird issues with 'Onward' VR with it giving me a double display but I'm currently working with a dev regarding the problem (this seems to be happening to other Onward players too since an update)
I've found that games optimized for NVidia GPU's seem to have issues if you attempt to set fps limits, use vsync or 'boost' through AMD's GPU suite.
Correct me if I'm wrong but I'm reading that the majority of the issues are related to the XT version?
I must be lucky with my 5700XT, i switched from a R9 280X which also had no problems with drivers and worked fine.
Ryzen 3600 4.33ghz . CM Hyper 212 Turbo. MSI X470 Gaming Plus Max. Crucial Ballistix Sport LT 3200 @ 3200 CL 15 (OC). Powercolor RX 5700XT Red Dragon. FD Meshify S2. Crucial P1 M.2 1TB. Corsair Vengeance 650W 80+ Silver.
Core 2 Duo 3.4ghz . WenjuFeng cooler . ASUS P5G41C-M LX . Crucial 1066mhz 3GB DDR2 . Gainward Golden Sample HD 4850 . Coolermaster Elite 430 . Seagate 160GB IDE 7200RPM . BeQuiet System Power 9 400w 80+ Bronze
I truly wanted the AMD card to be good. I had wanted everything to be at 7nm in my chassis. Last thing I wanted is to return the card. I really wanted the AMD card to work great. Just not stupid enough to buy the same thing and expect different results. On a better note, My 3600x is great. I just wish AMD would put out a better , stable card in which the drivers work proper. I love this RTX 2060 Super. Not sure if the RT thing improves how games look enough to justify a performance hit. Tried Shadow of the Tomb Raider with DLSS on and It really isnt all that special. At least the card is stable and the drivers work
