Silly Question... What could happen and what I could do if I put a GTX 1070 Ti + 970 on my system.
Basically the title, this probably is just plain dumb and I think that probably it wouldn't boot.
Could I use the 970 for physx?
Or this is just doesn't have any use.
Thanks! :D
Edited by jeanic
Title Edit.
ASUS P8P67-M PRO / Intel Core i5 2500 / Corsair Vegeance 16 GB 1600 MHZ / Asus Strix GTX 970 / Cooler Master GX 650 Watts 80 Plus / CM Storm Enforcer
Thanks! :D
It will be useless basically.
You could have an additional three screens.
Using it for PhysX is kind of pointless because of how few games use it extensively enough to warrant a dedicated physics processing unit.
It will work, albeit most games want a more powerful cpu
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
it'd work excellently for folding@home, but it wouldn't do a whole lot for gaming
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
Might cause the pc to blow up. Or do nothing. Who knows.
Thanks! :D
Why would you think that having 2 graphics cards would prevent booting?
Yes you could. You shouldn't, but you could. It will be slower than just letting the 1070 Ti do everything.
It could have use if you were doing some kind of rendering that could make use of multiple un-linked graphics cards but for general PC use or gaming it is pointless.
HEDT: i9 10980XE @ 4.9 gHz, 64GB @ 3600mHz CL14 G.Skill Trident-Z DDR4, 2x Nvidia Titan RTX NVLink SLI, Corsair AX1600i, Samsung 960 Pro 2TB OS/apps, Samsung 850 EVO 4TB media, LG 38GL950G-B monitor, Drop CTRL keyboard, Decus Respec mouse
Laptop: Razer Blade Pro 2019 9750H model, 32GB @ 3200mHz CL18 G.Skill Ripjaws DDR4, 2x Samsung 960 Pro 1TB RAID0, repasted with Thermal Grizzly Kryonaut
Gaming Rig: i9 9900ks @ 5.2ghz, 32GB @ 4000mHz CL17 G.Skill Trident-Z DDR4, EVGA RTX 2080 Ti Kingpin, Corsair HX1200, Samsung 970 EVO Plus 2TB, Asus PG348Q monitor, Corsair K70 LUX RGB keyboard, Corsair Ironclaw mouse
HTPC: i7 7700 (delidded + LM), 16GB @ 2666mHz CL15 Corsair Vengeance LPX DDR4, MSI Geforce GTX 1070 Gaming X, Corsair SFX 600, Samsung 850 Pro 512gb, Samsung Q55R TV, Filco Majestouch Convertible 2 TKL keyboard, Logitech G403 wireless mouse
I'll keep it stored till I get enough money for a second build to giveaway to a cousin.
Thanks for all your replies!
Thanks! :D
You could but it's not really that useful since you can't use it as a SLI setup, and even if you could, it would only operate at the performance of the 970.
It's the same with pairing a Radeon or using the iGPU. There are some specific OpenCL/CUDA/GPU-Compute purposes where this can be used, but it's not going to help much at all in games since the presence of the second GPU will impair the number of PCIe lanes already on the MB. So you might have 16 lanes to the 1070, but with the 970 also installed, they only get 8 each.
That depends on where the second card is installed. Also a 1070 isn’t gonna saturate 16x. Would perform the same.
You could use the 970 as a dedicated method of recording game footage (using OBS)
Not streaming, but offloading a high bitrate NVENC recording so that it doesn't interfere with your CPU/GPU gameplay.
        Weem
Experts on here say that isn’t possible.
With Blender Cycles, you should be able to use both cards in a render, though the scene must fit into the VRAM of the card with the lowest capacity.
Basically, compute applications are the only thing remotely commonplace that would utilize the performance of such mismatching GPUs simultaneously.
My eyes see the past…
My camera lens sees the present…
