ISO an ITX case that would fit two 3.5" HDDs
Hey guys. I'm trying to build a small form factor server to run Plex Media Server. I don't want to use a NAS, since I will need to do a lot of heavy transcoding. So I was looking to build a small Ryzen-based system. The caveat is that I also want to be able to mount two 3.5" HDDs for all my media storage. Anybody know of a case that would hold an ITX Mobo and system, but still has two large HDD bays?
https://linustechtips.com/topic/1133521-iso-an-itx-case-that-would-fit-two-35-hdds/
There's plenty
What size of case do you want? How much?
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
Cooler Master Elite 130
https://pcpartpicker.com/product/6wR48d/cooler-master-case-rc130kkn1
Im eyeing it for when I rebuild my Plex server.
30 minutes ago, gueye said:
Really trying to go as small as I can but still fit the two HDDs. I don't need room for a graphics card if that helps.
What about something like this?
I'd replace the power supply though.
https://pcpartpicker.com/product/mcQypg/inwin-case-bp655fh300tb3
Power supply isnt ATX or SFX, so finding a "good" replacement would be difficult. (Is that flex? I'm not even sure) I'd imagine the included one is "fine" for media storage (no heavy loads)
My personal recommendation would probably be the Silverstone ML03 or ML04
https://pcpartpicker.com/product/bWR48d/silverstone-case-ml03b
https://pcpartpicker.com/product/fsw323/silverstone-case-ml04b
True. It’s TFX. However last I checked seasonic has a decent one
