How to throttle WiFi speed on ZTE ZXV10 W300
Solved by Alex Atkin UK,
If you want to provide access like that then best bet would be to buy a cheap router/Access Point that DOES support OpenWRT.
Then you could plug the WAN port into your LAN and setup QoS to your hearts content, knowing its not going to upset your main WiFi. But as others have said, use a password, don't just leave it open.
Featured Topics
cringowy ·
Pekokopiko ·
Posted in Graphics Cards0 -
1
deanx ·
Posted in Troubleshooting2 -
Bkstrat ·
Posted in Troubleshooting0 -
3
remo233 ·
Posted in Power Supplies5 -
2
3
VioletGiraffe ·
Posted in CPUs, Motherboards, and Memory3
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
