is there a best ethernet cable?
Solved by goto10,
yes, you shouldnt use nothing under cat 5e, and has to be copper, there are cheap versions that dont have copper, those are garbage
i only use cat6 now, is a bit more expensive but doesnt give me problems
Featured Topics
Foure ·
Posted in Linux, macOS and Everything Not-Windows0 -
zacharrison ·
Posted in General Discussion2 -
ben_bennie_nie ·
Posted in Audio0 -
logan mcd ·
Posted in Graphics Cards1 -
2
3
6
Fireord36 ·
Posted in New Builds and Planning3
