monitor
INotPablo
Hello, I'm going to buy a PC with Ryzen 5 7600 and I think the graphics could be RX 7800 XT or something better (I'm going to buy the graphics card at the end of this year)
Well, my problem currently is that I don't have such a high budget for the monitor (I spent almost everything on the PC).
Well, I wanted to play with a 2560 x 1440 monitor at 165hz but I don't have that budget, well, what do you recommend?
Or I'll buy a 165hz monitor at 1920x1080 or a 60hz one with that same resolution while I save for a better one.
or buy one of 2560 x 1440 unknown Chinese brand
budget of approximately $120
Can you show the whole build and total budget? I'd take a lower end GPU and a better monitor over a higher end GPU and a 1080p screen here.
I'd really suggest getting a cheaper build and a better monitor here.
As mentioned above I would easily get a slightly lower tier GPU and a 1440p 144hz monitor over a 1080 60hz monitor.
Buy used.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1920x1440@65Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz
Gateway VX900 CRT: 1920x1440@64Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
