Is TB to 10Gb Ethernet as simple as it seems?
Fasauceome
A client needs 10 gigabit connection for an upcoming outfitting to a NAS and was originally thinking of using a 10Gb PCIe expansion card, but he's already using so much PCIe bandwidth as it is. I suggested a 10Gb adapter from Thunderbolt that he'd also be able to use with his mac for more convenience, and I found some adapters, but I have reservations about any simple plug and play capabilities.
https://www.bhphotovideo.com/c/product/1404413-REG/sonnet_solo10g_tb3_solo_10g_thunderbolt_3.html?ap=y&smp=y&lsft=BI%3A514&gclid=CjwKCAjw67XpBRBqEiwA5RCoca_eYjtR_GwjzK40Pi935dGix565PvvMp-S5KsSPipIkzFUUjdhkrhoCv_MQAvD_BwE
These things sure aren't cheap, so I'd like to know if people have had problems with these.
Primary PC:
I have heard good things about it, especially on macOS. When it comes to PnP on macOS, the worst thing you need to do is download drivers. I can't speak to this specific adapter, but even really cheap Amazon adapters without explicit macOS support have worked without any real issue.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
Nice, usual when something seems too good to be true that's the case. What would fall under a cheap adapter?
Primary PC:
Something like this (this is the exact one I have, actually)
https://www.amazon.com/gp/product/B00MYTSN18/ref=ppx_yo_dt_b_asin_title_o04_s01?ie=UTF8&psc=1
Useful threads:
Total: $1891.98
I have one just like that, ideally thunderbolt is just as convenient as USB for an adapter
Primary PC:
TB3 is needed for 10Gb, which makes the difference.
Useful threads:
Total: $1891.98
Quote
Its not like Thunderbolt is going to magically get around that, it will still be taking up PCIe bandwidth, depending on exactly how its wired internally could be better or worse than a PCIe slot.
There is no denying that TB wins when it comes to being able to easily use it on other devices though.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
It's just that he won't be using 3 thunderbolt devices, a PCIe SSD, and a 10Gb connection all at the same time and say "hey what happened to my bandwidth"
Primary PC:
TB is just an external way of hooking up to the PCIe bus though, so unless its has dedicated PCIe lanes (unlikely) its still contending the same as a internal card would.
It still sounds a good choice for being able to switch it to the Mac when required, but it should make zero difference compared to PCIe when it comes to actual bandwidth available on that system.
