Hi! I have an issue where if I plug in the CPU cables from the motherboard (Gigabyte x670e aorus master) into the PSU, nothing turns on except for the RAM rgb.
If I unplug the CPU motherboard cables from the PSU, the fans spin and RAM rgb turns on, so I don't think it's a PSU issue(?). Nothing else still turns on though.
I bought brand new parts so I hope it's not a CPU/motherboard issue 😞
Thanks for any help!
https://linustechtips.com/topic/1570063-motherboardcpu-issue/
You are only using cables that originally came with the power supply, correct?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1570063-motherboardcpu-issue/#findComment-16406931
